What fan header of the motherboard did you plug it in? What motherboard do you have?
https://linustechtips.com/topic/1138211-phanteks-p300-fan/#findComment-13158744
24 minutes ago, slashbrackets said:
Motherboard is MSI Tomahawk B450. And I just realized I followed the wrong wire. I found it, it's not connected. Doh!
But which fan port should I connect it to?
PUMP_FAN1
SYS_FAN1
SYS_FAN2
SYS_FAN3
SYS_FAN4
Any of the sys_fan headers, probably closest to the fan.
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1138211-phanteks-p300-fan/#findComment-13158839
