Ok so I bought a used 1060 6gb, and it ran perfectly fine on the guy's build when I tested it
On my PC I can't find any drivers, so literally nothing in any part, I can't find the Nvidia control panel even though I got it from the Microsoft store
So I built my PC today, and I went to install drivers for it, finding them on Nvidia's site, I download the latest version, it goes through the compatibility phase, I choose what I want to be installed and then it goes. It starts installing graphics drivers, but it gets to the letter G, stops and then it doesn't go further, after 5 minutes it stops trying and just doesn't install the drivers or any of the other software
Any help is appreciated, thanks!
https://linustechtips.com/topic/1137934-need-help-with-graphics-drivers/
2 minutes ago, bronzesilver said:
DDU? I haven't heard of that, but I have tried to Install offline and it still fails
DisplayDriverUninstaller. Might give this a try to see if it works.
First: grab the latest NVIDIA installer
Second, disconnect your computer from the internet
Third, follow DDU instructions. DDU recommends use it on safe mode if I remember
Fourth, reboot your computer once DDU done
Fourth, install gpu drive in normal mode
DDU is a tool called Display Driver Uninstaller. It will completly wipe any driver you have, so you can install the latest version without any possible conflicts from previous drivers.
I do it before every driver update to remove useless junk from previous drivers.
DDU = Display Driver Uninstall, google it up, download and install, you'll get nagged about rebooting in Safe Mode..up to you; I never bothered and no probs...but that doesn't mean you'd have the same result. Can only try it and hope for the best...my only other concern or question would be; are you certain the card is a genuine name brand item? Not a cheapo Chinese rip-off copy with say a GTS 450 BIOS been tweaked to read as something else?
And that's where I have an issue, since I have no drivers installed, I can't know for sure. I mean, from the outside it looks like a Gigabyte Windforce OC 1060, it appears like that in device manager but Im still not sure. I have downloaded GPU-Z but it just shows blank spaces where the values should be, possibly since I have no drivers
Or if you not sure just open the card and check the number on the die ( after you clean thermal paste) should be GP106-400-A1 if you see any other number it means fake card. Just remember to apply new thermal paste when putting it back together.
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
