If you want serious budget then go to amazon and get RGB strips, they won't be powered by your PC but you'll have RGB.
First cheap amazon result I clicked on RGB LED
(everyone should know to look at links before they click them, bottom left corner of browser.  microsoft.scam.com is from scam.com microsoft.com is microsoft)
But anyways if your only concern is budget I'd say go for the cheapest kit you can find, I don't have any brands as the RGB is off in my system and I haven't followed it.  Get the correct connector or controller and you're done
Audio go Brrrrrr
https://linustechtips.com/topic/1137871-help-needed/#findComment-13157027
