Hi guys, I have a dilemma, My choice is between a Zotac 2080Ti  Amp Extreme or a ASUS ROG STRIX 2080 Ti. The Zotac I have had in my current system for the last 6 months paired with an i7 9700K. I am replacing this rig tomorrow with a AMD 3900X setup as my use case has changed and I am in need of the extra horsepower (will be working from home instead of the office) In my brief research online I cannot see much between them in terms of performance, I think it may just come down to aesthetics. I do play AAA games as well as occasionally stream. Any thoughts will be much appreciated.
Thanks,
https://linustechtips.com/topic/1137572-first-world-problem-help-me-choose/
Seeing as you already have a 2080ti.... why not just use the one you have? lol.
Yes, there is no difference, not one worth spending money over. Some may boost a little higher, but that will be relatively negligible, certainly not worth selling your current card at a loss to buy a new one.
Thanks,
There isn't much difference as  @LIGISTX said
Please quote or tag  @Ben17 if you want to see a reply.
If I don't reply it's probly because I am in a different time zone or haven't seen your message yet but I will reply when I see it ?
