Motherboard help
Go to solution Solved by minibois,
From the BIOS update notes I don't see that. The 3200G is even on its QVL, with a GPU speed mentioned too; so can't imagine the iGPU not working on that CPU+board combo.
But I would recommend a simple B450 board anyways, like a B450 Aorus M would even work fine.
Will I be able to make use of an iGPU ( 3200G) once I update the bios on this motherboard ( Gigabyte A320M S2H AMD Ryzen Socket AM4 Micro-ATX Desktop Motherboard) to the required bios ? I've heard people say that you can't use the hdmi port once you update the bios to the required bios that supports the 3000 series
https://linustechtips.com/topic/1137567-motherboard-help/
https://linustechtips.com/topic/1137567-motherboard-help/#findComment-13154176
To add to this, a B450 board is better than an A320 because even if you don't care about any extra I/O or features, it enables overclocking the processor, which could be useful in the future. Additionally, it has a higher chance of supporting future processors. A hypothetical 4400G which you might want to upgrade to some day will have a higher chance of being supported on B450 than A320.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/1137567-motherboard-help/#findComment-13154225
I dont see why the video output wont work after a BIOS update, because that's considered a bugged one that should not see the light of day.
Desktop benching:
https://linustechtips.com/topic/1137567-motherboard-help/#findComment-13154276
