Kind of depends on what you're going to be doing/playing and at what resolution and refresh rate, I'd say...?
Make sure to tag and/or quote people so they get notified... :P:D
My gear:
                                                         Ryzen 7 2700X / Gigabyte GA-X370M-Gaming 3 / R9 380 Nitro 4GB/ 16GB DDR4 2133 / 225GB OCZ Trion 100 / 3TB of hard drive storage
        AOC C24G1 / BenQ GW2270H(rarely overclocked to 87Hz :P )
        Razer Blackwidow / Redragon Kumara / Logitech G Pro Wiress / Sennheiser HD 559
        Microsoft LifeCam Studio / Tonor BM700 microphone
Panasonic Lumix DC-FZ82 / Canon EOS 80D
#PCMasterrace
https://linustechtips.com/topic/1137556-do-i-need-a-better-cpu/#findComment-13154092
20 minutes ago, Lorant said:
Nope.  Will be fine.
20 minutes ago, emosun said:
No , the cpu is compatible with the gpu. I think that entire series of cpu doesn't have any known issue as of yet with the gpu.
Well then what is the point of the r 5 3600 for mid range / upper mid range graphics cards
https://linustechtips.com/topic/1137556-do-i-need-a-better-cpu/#findComment-13154150
higher end cpus are for higher end  loads.
you've listed no form of cpu requirements so you don't need to change your cpu to use that gpu
https://linustechtips.com/topic/1137556-do-i-need-a-better-cpu/#findComment-13154159
Just now, emosun said:
ok so do you need that cpu or......?
There should be no one who buys the r 5 3600 becuase it cost 100$ more and gives only about 10$ more performance so if you have a r 5 3600 than you should re think your life choices
https://linustechtips.com/topic/1137556-do-i-need-a-better-cpu/#findComment-13154185
From personal Experience, a R5 2600/2600X is a fantastic CPU for the Radeon 5700/5700XT graphics cards. Currently sporting a 2600X and a 5700XT, most games I get anywhere from 90 to 144+ FPS, depending on game. For Example (1080p resolution):
RDR2: 98FPS on High
Overwatch: 158FPS on Ultra
COD: MW: 135FPS on High
Forza Horizon 4: 148FPS on Ultra
Gears 5: 120FPS on High
I am also using the reference card. I have heard of other people achieving higher frames on the custom cards.
CPU: Ryzen 7 5800X GPU: Sapphire Pulse RX 9070XT Motherboard: Asus ROG Strix X470-F RAM: Corsair 32GB Vengeance 3600Mhz PSU: Corsair RM850X White
Cooling: Corsair H115i RGB Storage: Samsung 970 Evo NVME (2TB) Case: NZXT H500i White
Keyboard: Corsair K70 Mechanical Mouse: Logitech Superlight 2
https://linustechtips.com/topic/1137556-do-i-need-a-better-cpu/#findComment-13154195
according to benchmarks the cpu's have a 30% speed difference between them when accounting for the total speed. these may vary if you are using a program that still is not compatible with muticore cpu's. However people who buy the 3600 are more than likely not concerned with older or lower end tasks like that.
More than likely if they have more money then I'm sure they are comfortable in their life choices.
https://linustechtips.com/topic/1137556-do-i-need-a-better-cpu/#findComment-13154197
More than likely if they have more money than I'm sure they are comfortable in their life choices.
Ok i don't really want to have a disscusion so i will leave it at that
https://linustechtips.com/topic/1137556-do-i-need-a-better-cpu/#findComment-13154201
