Need some tech tips
Solved by Lee989,
There are two M.2 slots. M.2_1 (top) and M.2_2 (bottom).
M.2_1 will disable SATA port 1 if you use a SATA M.2 device (because it needs to use the bandwidth from that port, all other SATA ports remain usable). The Samsung 970 Evo is an NVMe device, so it will NOT disable SATA port 1.
M.2_2 I believe disables SATA ports 5 & 6 in order to run at full speed for NVMe devices. Ports 1 - 4 remain usable (unless you also have a SATA device in M.2_1 in which case ports 2-4 remain usable)
TLDR; Plug your Samsung Evo into the top M.2 slot, plug your Barracuda into any SATA port. Won't be a problem
