Hi all! Please check my build. I'm gonna use it for (mostly) gaming (1440p144hz). Anything I should add/change?
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  (€199.00 @ Azerty)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard  (€114.85 @ Azerty)
Memory: G.Skill Trident Z RGB 16 GB (2 x 8 GB) DDR4-3600 Memory  (€136.48 @ Newegg Netherlands)
Storage: ADATA XPG SX8200 Pro 1 TB M.2-2280 NVME Solid State Drive  (€138.95 @ Azerty)
Video Card: PowerColor Radeon RX 5700 XT 8 GB Red Devil Video Card  (€495.00 @ Azerty)
Case: Fractal Design Meshify C ATX Mid Tower Case  (€89.00 @ Azerty)
Power Supply: Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  (€75.99 @ Azerty)
Total: €1249.27
Generated by PCPartPicker 2019-12-22 19:36 CET+0100
https://linustechtips.com/topic/1137191-first-pc-build/
Seems to me to be a pretty standard modern gaming rig.  I don’t see any issues.  The nvme is a choice and the PSU is a choice.  It might be possible to save some with slower stuff on storage, as nvme currently doesn’t do a whole lot over sata6 for gaming.  There’s An argument for it though regarding future stuff.  PSUs I know nothing about, though there is a tier list in the PSU subsection compiled by people that do.  Your PSU might be on it.  I have a suspicion that the 3700x will be longer lasting than the 3600, but it’s just a suspicion and nothing has happened yet.
https://linustechtips.com/topic/1137191-first-pc-build/#findComment-13151327
2 minutes ago, boggy77 said:
Looks good. Might one to add a cooler if you find the stock one is too loud or hot.
One possible option is to upgrade to the 3600x. It comes with a slightly better cooler.  Depends on price difference though.  The cooler isn’t ALL that much better and the chip is nearly the same.  It would have to be real close.
https://linustechtips.com/topic/1137191-first-pc-build/#findComment-13151730
