Hi, I've just switched from HDMI to VGA using DVI to VGA adaptor.
My monitor resolution is 1920 x 1080, but now there's a back bar at the right side of the screen.
I can also see vertical stripes down the screen. Any ideas of how to fix this?
My graphics card: EVGA GTX 1050 TI SC
https://linustechtips.com/topic/1137088-resolution-problems-with-vga/
17 minutes ago, PremierSupreme said:
I think the problem is I have a wide screen monitor.
Edit: I have seen other users with HDMI to DVI, so perhaps that will work.
VGA was never designed for these resolutions, so that could be the issue. A good GPU + cable should be able to do it though. DVI, HDMI or DisplayPort are the better options though.
Why would you do that?
F@H
GPD Win 2
