Hi, I recenlty bought a gtx 1660 ti oc windforce as an upgrade to my pc, my power supply is Segotep H9Plus+ 520W and before this gpu I had a gtx 1050 ti, which dosent require any external power, I mean you don't have to connect any cables from the power supply to the gpu. When I was installing my new gpu, I noticed I didn't had an 8 pin cable to connect from the power supply to the gpu, my power supply 6+2 pin port is male type, and the gpu male aswell. What cable do I need to buy? P.S I am from Romania, I can't buy stuff from US or things like that, I am more interested in the type of cable I need, not the link from where to buy it. Does this one work? https://www.emag.ro/cablu-adaptor-pentru-alimentare-pci-e-6-pini-mama-la-2-x-8-pini-6-2-tata-20cm-puls013/pd/DT5YCZBBM/?cmpid=86840&gclid=Cj0KCQiAovfvBRCRARIsADEmbRJkTmy-VYHvpf94n_wI0Z-HDHPpR1wLOS1rRdDtL1zdBzLX3pNP-oAaAgagEALw_wcB
https://linustechtips.com/topic/1136940-need-help-asap/
check again, they don't make male PCIe connectors on graphics card. any 6+2 connector you have should be fine to work properly.
don't buy this, it splits a connector designed for 75 watts into two designed for 150
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1136940-need-help-asap/#findComment-13149335
I dont have any cable whatsoever, the only cable that came along with the pc when i bought it was a sata, I need a cable to connect the gtx 1660 ti to the power supply, it says it requires 8 pin connector
https://linustechtips.com/topic/1136940-need-help-asap/#findComment-13149355
What exactly does this mean then? It sounds like you have a connector.
If you do not have a PCIe power cable at all, the adapter you linked does not work anyway.
The rule of thumb is that if your power supply does not have the right connector for the job it is not adequate. Consider an inexpensive PSU to replace it such as a Corsair CX450, which will have an 8 pin PCIe connector.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1136940-need-help-asap/#findComment-13149362
I bought my PC prebuild from a popular company in my country, probably they forgot to give me the other cables that came with the psu, since the 1050 ti I had didn't required a 6 pin or 8 pin. My PSU has 6+2 PCI, it is written on it, but I do not have the cable to connect the PSU to the GPU. I might miss on something you're saying, sorry for that cuz this is my first pc and I'm new to this.
https://linustechtips.com/topic/1136940-need-help-asap/#findComment-13149367
Ok that is different, so it has PCIe female ports.
Contact the company who built the PC, they owe you the cables.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1136940-need-help-asap/#findComment-13149376
1 hour ago, dariuss54 said:
No.
That's a splitter that splits a single 6-pin into two 8-pins.. which right there is shady as f***.
https://linustechtips.com/topic/1136940-need-help-asap/#findComment-13149427
Something you say does not make sense (to me).  The cable you show is female to male.  You state the PSU cable connection (please be clear it is the end of cable connection - not the plug at the cpu) is male and the card is male.  That doesn't make sense. Fasauceome is correct.  I would not buy the splutter cable unless you only plan on using it as an adapter for a single 8 pin....but I have a feeling there is something else more important wrong.  Best bet, take pictures of the cable ends you mean. That will make it easier.
https://linustechtips.com/topic/1136940-need-help-asap/#findComment-13149885
12 hours ago, Mantabase said:
He/she is in Romania.  What brand and model would you suggest that is available there?
Segotep has some good models.  Just not that one.  That one is Segotep's cheapest model.
Otherwise, I don't know what else is available in Romania because you didn't provide us a link to any stores.
https://linustechtips.com/topic/1136940-need-help-asap/#findComment-13150946
10 hours ago, dariuss54 said:
Thats the PSU
Not exactly what I meant.  But I think I understand what you might mean.
JonnyGuru is right - that splitter is dodgy.  But if what you say is true, it won't work anyway.  That is what was confusing.  I think what you mean is you are missing the entire cable that goes from PSU to the GPU's PCIe plug?  If so, those are usually special cables and can be specific to the PSU maker.  EDIT:  If the PSU is designed for it - the cable should have come with it.
https://linustechtips.com/topic/1136940-need-help-asap/#findComment-13150955
CX450 is available at the shop OP was using for the adapter cable.
https://www.emag.ro/sursa-corsair-cx450-450w-80-bronze-cp-9020120/pd/DWNMZ7BBM/
Though I'm not sure why the product information listed on that website shows it working with Corsair Link (iCue). The CX450 definitely does not support digital monitoring :D
https://linustechtips.com/topic/1136940-need-help-asap/#findComment-13150956
Well, the OP provided a link.  https://www.emag.ro/search/PSU?ref=effective_search
There are more choices than I thought.
https://linustechtips.com/topic/1136940-need-help-asap/#findComment-13150958
Yeah - I caught that link - not sure why I didn't check there first.  Thanks.  It was a total "oh duh" moment on my part.
https://linustechtips.com/topic/1136940-need-help-asap/#findComment-13150963
https://www.compari.ro/surse-de-alimentare-c3158/?orderby=13  I like this site for comparing prices and seeing the range of available products. :)
This Seasonic Core GC 500w looks affordable.
https://www.compari.ro/surse-de-alimentare-c3158/seasonic/core-gc-500w-gold-ssr-500lc-p496751859/
Life is really challenging. I don't always suceed: )
https://linustechtips.com/topic/1136940-need-help-asap/#findComment-13150975
