 Hi guys.
I'm building a mini ITX PC that'll be used primarily for VR (Valve index).
Any tips or things I need to change?
Have I missed something, or is there any compatibility issues between the parts and the case?
Thank you in advance.
https://linustechtips.com/topic/1136306-mini-itx-vr-build/
Here's some changes, you were overspending quite a bit.
Are you set on that case? It's not very small for an itx system and you don't have any extra hard drives
https://linustechtips.com/topic/1136306-mini-itx-vr-build/#findComment-13144277
Thank you for the quick reply!
Definitely a price difference there.
I see you've chosen a full size PSU. Isn't it too big to fit such a big GPU in the case?
Do you have any other recommendations for cases? I don't nessesarily want that case :)
https://linustechtips.com/topic/1136306-mini-itx-vr-build/#findComment-13144287
That case is definitely big enough to support it, that's why pcpartpicker is so good- it'll tell you when you're dumb haha
For case, If you're still okay with a boxy shape- the SG13 is fantastic
If you wanted a more xbox, flat case - the node 202 is a decent option.
https://linustechtips.com/topic/1136306-mini-itx-vr-build/#findComment-13144293
Which of those cases would you recommend? Keep in mind, it'll be sitting inside my TV stand. Airflow has to be decent :)
https://linustechtips.com/topic/1136306-mini-itx-vr-build/#findComment-13144296
Either are decent, the SG13 is definitely better for cooling though. Node 202 is known to be a little more choked
You would need to change the gpu though- the evga card is slightly too long for that case.
https://linustechtips.com/topic/1136306-mini-itx-vr-build/#findComment-13144300
SG13 looks amazing. I am however set on the specific GPU :(
Do you have experience with Node 304 and Node 202?
- Which case will provide the best cooling, assembly and build quality?
I also need some good fans and a better CPU cooler.
https://linustechtips.com/topic/1136306-mini-itx-vr-build/#findComment-13145219
Both cases would be out of question if you have to use that gpu
I'd probably go with something like the core 500.
The core 500 will come with one exhaust fan, but you can put in an extra intake at the front. I really like noctuas.
The ryzen stock cooler will also be sufficient if you're not overclocking, or doing a small overclock.
https://linustechtips.com/topic/1136306-mini-itx-vr-build/#findComment-13145431
Why is the GPU out of the question? It seems to fit according to length etc
https://linustechtips.com/topic/1136306-mini-itx-vr-build/#findComment-13145862
With the sg13, it's about 1/3 of an inch too big
And yeah I guess the node 202 supports it- I thought it was shorter!
https://linustechtips.com/topic/1136306-mini-itx-vr-build/#findComment-13145930
