everything looks good, though i think that is a bit to hot for my liking. Voltage and frequency are perfectly safe though. i would just save up for a better cooler as that will let you oc even further at probably a lower temp depending on the cooler you get. actually i just read in your sig that you have an h100i. you may want to re-seat your cooler as i have a 4670k at 4.6ghz at 1.275 vcore and only get to around 72c. You should be getting better temps with an h100i
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/113617-cpu-overclock-and-temps/#findComment-1518352
Thinking of doing a full custom loop during the summer. Would it be worth it to go for full watercooling?
PLEASE USE PCPARTPICKER.  My rig: http://pcpartpicker.com/p/ZBmWjX
https://linustechtips.com/topic/113617-cpu-overclock-and-temps/#findComment-1518368
I have over clocked my CPU to 4.5GHz, is this a good OC? I My voltage is 1.2775. Also the max temp it hits while running Cinebench R15 is 85 Degrees Celsius, is this safe?
Mine gets hotter, but personally that's okay to me. Benchmarking pushes the cpu hard, nothing I do even comes close to what it pushes to. My max real world usage temps are 60c and that's fine for me.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/113617-cpu-overclock-and-temps/#findComment-1518376
just edited my post, you should try reseating your cooler, that temp is prety high for that voltage and clock speed on an h100i
https://linustechtips.com/topic/113617-cpu-overclock-and-temps/#findComment-1518380
Would fan orientation on the rad help as well as re-seating the block.
https://linustechtips.com/topic/113617-cpu-overclock-and-temps/#findComment-1518381
fan orientation should not matter too much, just for reference i have my fans i a push config exhausting from the top of my case. just try re-seating the cooler while using some better thermal paste. The stock corsair thermal paste is not that great. first time installing the h100i on my system and i was seeing temps resembling the stock intel cooler haha. New thermal paste fixed that right away.
https://linustechtips.com/topic/113617-cpu-overclock-and-temps/#findComment-1518401
Will do.
https://linustechtips.com/topic/113617-cpu-overclock-and-temps/#findComment-1518408
4.7ghz on an h212 :blink: What king of temps are you running haha. Thats insane!
https://linustechtips.com/topic/113617-cpu-overclock-and-temps/#findComment-1518420
When it comes to my Sandy bridge CPU using a Hyper 212, It automatically shuts the system down @ 100*c or maybe a little more.., throttles at 85*c+, and knowing that,..I always try to maintain a maximum temp of 80*c give or take a few degrees, with it rarely hitting that max unless testing/benchmarking the CPU, to which my average maximum for games and whatnot is 70-75*c with maybe seeing 80*c rendering.
Bios Fan profiles based on ramping up once you hit the target temp,...my fans from low speeds up until CPU @ 70*c when they are starting to spool faster.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/113617-cpu-overclock-and-temps/#findComment-1518428
102c when being benched but stable. Always stays below 65c with anything I've thrown at it in the real world. Using bench temps should be taken with a grain of salt. Maxing out all four cores rarely happens so I don't care how hot benchmarking gets it. I prefer real world usage temps. I have a lcd on my keyboard and I monitor the temps always. ;)
https://linustechtips.com/topic/113617-cpu-overclock-and-temps/#findComment-1518435
and here i am getting scared when my cpu goes over 70c haha. I'm guessing you must be somewhere north of 1.30 vcore to get that speed.
https://linustechtips.com/topic/113617-cpu-overclock-and-temps/#findComment-1518455
I've used laptops for years, I'm use to seeing temps close to 100c so it doesn't bother me. The hyper 212+ is just temporary, a h100i is coming in a month :) My vcore is actually 1.28v for that speed and it's stable. I've got it down to 4.5ghz now though just to see if there would be any temperature differences between the speeds and after over a week the temps are exactly the same. My vcore for 4.5ghz is 1.23v (any lower and it's unstable)
The max I've got my I7 to is 4.9ghz core voltage 1.35v and it was stable. I tried for 5ghz but I didn't up the voltage and it crashed, just doing a test to see how high it would go. I'll be doing a legit test for that when I get my h100i to help with the high temps at the time. Just wanna see how lucky I got. :)
https://linustechtips.com/topic/113617-cpu-overclock-and-temps/#findComment-1518471
The temperature is too hot. You need a better CPU cooler
an h100i is already an adequate cooler, so it's not the cooler maybe the chip.
I cannot go over 4.2GHz on mine because of temps even with my h110, so my silicone draw was just plain unlucky. Mine peaked at 95 degrees on small fft prime95 stress with a 4.4 OC. Just the luck of the draw mate
Rig
CPU: 4770k @ 4.2GHz 1.15v | Mobo: ASUS z87 Sabertooth | Cooler: Corsair H110 | RAM: Vengeance 32GB DDR3 @ 1600MHz | GPU: GIGABYTE G1 GTX 1070 | Storage: Samsung 840 series 250GB SSD, Seagate 2TB SSHD, Seagate 4.25TB HDD | PSU: Corsair AX850 80+ gold modu | Case: Corsair 650d | Keyboard: Corsair K65 RGB Cherry MX Reds & a Leopold 210TP Numberpad Cherry MX Blues | Mouse: Logitech G502, DECHANIC desk mat | Monitor: 2x Dell IPS 23" S2340m & ASUS 144hz 24" VG248QE | Speakers: CA-3602a | Headset: Steelseries Syberia v2 Frost Blue OS: Win 10 Pro
https://linustechtips.com/topic/113617-cpu-overclock-and-temps/#findComment-1518849
Some CPUs just don't get cool enough, regardless of how good of a cooler you put on it. But you might be surprised how heat tolerable some of these CPUs are.
My old 3770K hit 90 degrees all the time, on full load, and it never had a single problem.
I probably would have had been able to push OC a little more if temperature was a little lower, since I was able to hit higher clocks but then it would go 100 (LoL), so I backed it down a bit,
https://linustechtips.com/topic/113617-cpu-overclock-and-temps/#findComment-1523428
You want low 70's in cinebench.
Either the voltage is spiking past 1.2775 (adaptive), the cooler isn't installed right, or you got one reaaaaaaaaaaly hot batch of Haswell.
Those are the temps I would see at that voltage on a evo 212. H100i shouldn't be that high a temp at that voltage.
Low 80's can be "ok" in Aida, first round of prime blend. Past that? I would never render with those temps.
CPU:24/7-4770k @ 4.5ghz/4.0 cache @ 1.22V override, 1.776 VCCIN. MB: Z87-G41 PC Mate. Cooling: Hyper 212 evo push/pull. Ram: Gskill Ares 1600 CL9 @ 2133 1.56v 10-12-10-31-T1 150 TRFC. Case: HAF 912 stock fans (no LED crap). HD: Seagate Barracuda 1 TB. Display: Dell S2340M IPS. GPU: Sapphire Tri-x R9 290. PSU:CX600M OS: Win 7 64 bit/Mac OS X Mavericks, dual boot Hackintosh.
https://linustechtips.com/topic/113617-cpu-overclock-and-temps/#findComment-1523869
