OK so il start by listing my computer specs, im not that fond of the ''new'' fx chip i bought but here goes.
Motherboard:Gigabyte-990ga-ud3.
PSU:850W corsair RM850X.
CPU: AMD FX-8370.
GPU: TWO Asus gtx 780 direct CU II OC.
Harddrives: 3SSD's
RAM: 16gb Corsair vengeance 1600mhz ( yet cant get em to run at 1600mhz since its made for Intel stuff, well i can but the system dont run that good cus i cant change a timing to 160).
well thats about it, i was wondering what youre opinions are on what i should upgrade to and at the lowest cost possible. like motherboard and cpu or something idk, thats why im here to hear you guys's opinion. (sry for bad english)
https://linustechtips.com/topic/1135959-need-help-with-upgrade/
How much do you want to spend?
https://linustechtips.com/topic/1135959-need-help-with-upgrade/#findComment-13141160
Ryzen 5, cheap off eBay you can get the 1600 and the like. Affordable B450 boards are all the rage for budget gamers, the ASRock B450M Pro4 is a great call at the low end. Any cheap DDR4 3000 or whatever speed higher you'd like to spend extra on would do nicely.
You could probably sell your graphics cards and get yourself a GTX 1070 or something similar.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1135959-need-help-with-upgrade/#findComment-13141162
20 minutes ago, Reaperino said:
I dont really know, only playing on a 1920x1080 screen and would like to play over 60 fps on newer games atleast
your FX should be the first to go, swap it out for a ryzen 2600-3600+SLI capable board (unless you have enough to upgrade your GPU with the CPU).
https://linustechtips.com/topic/1135959-need-help-with-upgrade/#findComment-13141216
5 minutes ago, Reaperino said:
nah i think i only got moneys for RAM+Motherboard+CPU
Budget and country?
https://linustechtips.com/topic/1135959-need-help-with-upgrade/#findComment-13141230
im thinking of these two maybe either:
1x Intel Core i5-9400F Processor
1x ASUS ROG Strix B360-F Gaming, S-1151
1x HyperX Fury RGB DDR4 16GB 2666MHz (2x8GB)
OR
1x AMD AM4 Ryzen 5 2600
1x ASUS ROG Strix B450-F GAMING, Socket-AM4
what do? ryzen one is like 370 dollars and intel one is 430 dollars ( give or take its in swedish crowns so)
the intel has a bit better performance in some games, but its intel i mean they are pretty cashhungry compared to AMD at the moment, and what about upgrade potential from there? on either boards i mean.
Edited by Reaperino
Because why not
https://linustechtips.com/topic/1135959-need-help-with-upgrade/#findComment-13141233
the 2600 and 9400F are evenly matched now, but reviewers are noting that the i5s are stuttering again as compared to the ryzen 2600/3600 CPUs. neither of those boards support SLI so you'll only be able to use one 780.
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  (kr1613.00 @ Dustin Home)
Motherboard: Asus STRIX X370-F GAMING ATX AM4 Motherboard  (kr1391.00 @ Dustin Home)
Memory: Patriot Viper 4 16 GB (2 x 8 GB) DDR4-3200 Memory  (kr733.00 @ CDON SE)
Total: kr3737.00
Generated by PCPartPicker 2019-12-19 03:14 CET+0100
https://linustechtips.com/topic/1135959-need-help-with-upgrade/#findComment-13141304
why x370? b450 boards are better and cheaper
Type Item Price
CPU AMD Ryzen 5 2600 3.4 GHz 6-Core Processor kr1613.00 @ Dustin Home
Motherboard MSI B450-A PRO MAX ATX AM4 Motherboard kr1159.00 @ Dustin Home
Memory Patriot Viper 4 16 GB (2 x 8 GB) DDR4-3200 Memory kr748.00 @ CDON SE
  Prices include shipping, taxes, rebates, and discounts
  Total kr3520.00
  Generated by PCPartPicker 2019-12-19 12:13 CET+0100
https://linustechtips.com/topic/1135959-need-help-with-upgrade/#findComment-13142143
Type Item Price
  Total kr3520.00
because he has an SLI setup...?
https://linustechtips.com/topic/1135959-need-help-with-upgrade/#findComment-13142313
Type Item Price
  Total kr3520.00
this is compatible with eachother, doesnt matter with SLI, SLI is a dead gimmick imo...
https://linustechtips.com/topic/1135959-need-help-with-upgrade/#findComment-13142328
motherboard might be incompatible with CPU m8.
it's been almost 2 years since the BIOS for zen+ CPUs was released on the X370-F, they're not gonna have stock that old to warrant having to worry about compatibility. Even if it wasn't, AMD offers bootkits specifically for this situation.
https://linustechtips.com/topic/1135959-need-help-with-upgrade/#findComment-13142342
