(IDLE) CPU go to lower than base clock?
Go to solution Solved by minibois,
When you are not using your PC (CPU specifically) too much, the system will clock certain parts down to conserve energy.
A variance of 200-300Mhz of clocks is not weird too, when not fully using your CPU.
This is normal.
Is it normal if my cpu go to lower than base clock. Ex. Ryzen 5 2600 with 3.4ghz. when idle its going to 3.2-3.3ghz. Sorry for this strange question. I only know cpu only run at base clock - max clock.
Ryzen 5 2600 / MSI B350 Tomahawk / GALAX RTX 2060 6GB (1-Click OC) / Corsair Vengeance LPX 2666Mhz 8x2GB / ADATA SX6000 LITE 512 M.2 NVME / KLEVV 128 GB SATA / Seagate Barracuda 2TB 7200rpm / Seasonic Focus Gold 550W / Tecware Nexus C
Upgrade Plan: CPU: Ryzen 5 3600 RAM: GSkill TridentZ RGB 3200MHz/3600MHz MB: MSI B450 TOMAHAWK MAX
https://linustechtips.com/topic/1135415-idle-cpu-go-to-lower-than-base-clock/
This is normal.
This is normal.
Oh thank you so much
