I bought a dell poweredge r610, in hopes to use it for a home server. It has no OS on it, so i dont know where to start. My goal is to have a server that can A.) Host a minecraft server, B.) Run with raid for drives, and C.) Be a storage server for home. I dont know much about this stuff, but the most important thing is the storage. I want to be able to drag and drop files via the NETWORK tab in Windows 10 file explorer. Any help would be appreciated. discord is a good form of communication for me, so mine is Sin Eater#5417. Thanks in advance!
https://linustechtips.com/topic/1135234-help-starting-a-server/
Perhaps just use UnRAID which is very popular for doing your storage, Linus and other YouTubers have plenty of videos on it.
Then Minecraft you could run in a VM on UnRAID with MineOS Turnkey to easily create/configure/manage
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/1135234-help-starting-a-server/#findComment-13135490
This'll be surprisingly long, yet still rather general. I hoped to demonstrate it's not that complicated, but my delivery skills aren't particularly great.
I recommend Debian, "netinstall" image saves space and is the modern way to go. You can create bootable USB with Etcher. I prefer going with normal install (not graphical), and installing only the essentials (it asks you what bundles you want to preinstall, it'll make sense when you get there).
Once you have the system up and running, log in to su (type su and press enter, it'll ask your administrator password). Install sudo by entering "apt-get install sudo", once that's done, make your normal account a sudoer (this command keeps changing, if "usermod -aG sudo username" doesn't work, turn to Google). Hit CTRL+A+D and log in to your normal account.
For Minecraft and filesharing you'll need JDK and Samba (there's probably alternatives to Samba, but my knowledge is, in the scheme of everything, extremely narrow). With program called screen, you can keep your Minecraft running undisturbed. You'll probably also want remote access with SSH, we'll use openssh-server for that. You can install all of them with a combined command: "sudo apt-get install openssh-server screen default-jdk samba", and from there you can probably already pick up how to install additional software. I find this far easier than any graphical implementation.
If you want to try a web server while you're at it, just install "apache2 default-mysql-server php php-xml php-mbstring php-mysqli". Some may have changed, it's important to read what the OS is telling you. Additional setup is required, and setting up the MySQL will take particular care, so be prepared to hit Google (start with entering "mysql_secure_installation").
I suggest you start moving to your main PC now. You can find the local IP of your server with "ip address show" (there's almost certainly a better way, but I haven't bothered). Get Putty or Putty Tray (latter has some nice candy), enter the IP and connect.
Once all that's done, create a new folder for your Minecraft server by entering "mkdir foldername", you can browse the directories with "cd foldername", "cd /path/to/somewhere", and "cd .." to go up a folder. It's very efficient once you get used to it. You have a home directory, and I suggest you use it for stuff like Minecraft servers (/home/username/minecraft). To remove folders use "rm - r foldername", and to move files or folders, you can use "mv /thing/that/moves /place/it/moves/to".
Once you're in the right folder, enter "screen" so your server won't close once you log out. To download Minecraft, get the newest file from Mojang ("copy link address") and download it using wget (for e.g. "wget https://site.tld/somecan.jar"), once that's done just follow Minecraft's instructions. After it has created the eula.txt and prompts you to edit it, you can use "nano eula.txt", see the bottom of the screen for nano's commands. You can exit the screen with CTRL+A+D, and you can have multiple screens running at the same time (albeit changing between them isn't very convenient IMO, maybe I'm doing it wrong).
I haven't used Samba in a while, and I frankly prefer just using SFTP so I can't come up with any of the steps off my head. It will however get you where you can just use the normal Windows Explorer and browse the server like it's local storage. I have this wiki in my notes.
Finally, you can keep the server up to date with "sudo apt-get update && apt-get upgrade". Choosing linux for your server will be by far less effort and much more stable in the long run. Going with everyday Windows might be tempting for its familiarity, and it'll probably do the job, but the chances of it biting you in the behind are alarmingly good.
https://linustechtips.com/topic/1135234-help-starting-a-server/#findComment-13135849
