Just now, MrSushiGaming said:
Looking for a power supply for around 50$. Specs are Radeon vii, ryzen 3700x,
USD $50 is really the entry point for power supplies these days. Radeon VII is quite a power hungry card so you may want to spend a little extra to get something that is better suited for the system. If you can increase the budget to $80-$90 it would give you access to a lot better options.
https://linustechtips.com/topic/1134940-power-supply-help/#findComment-13132721
3 hours ago, MrSushiGaming said:
gx-s is fine, surprisingly a sifra, considering cougar is owned by the same company as hec
https://linustechtips.com/topic/1134940-power-supply-help/#findComment-13133920
What abt this:
https://www.amazon.com/gp/product/B01CUEFO0Y/ref=ox_sc_act_title_1?smid=A20NV9CRQIRRW5&psc=1
yes ik I’m trying to lowball the hell out of the power supply.
https://linustechtips.com/topic/1134940-power-supply-help/#findComment-13133944
which is a horrible thing to do in the first place
i have little info and trust in older enermax psus, some of their new ones are okay, but this one i know too little about to recommend
https://linustechtips.com/topic/1134940-power-supply-help/#findComment-13133947
https://www.amazon.com/Thermaltake-Certified-Continuous-Active-PS-SPD-0700NPCWUS-W/dp/B014W3EAX8/ref=sr_1_8?crid=378RLA3WW962D&keywords=650w+power+supply&qid=1576510747&s=electronics&sprefix=650w+power%2Celectronics%2C417&sr=1-8
This?
https://linustechtips.com/topic/1134940-power-supply-help/#findComment-13133968
https://linustechtips.com/topic/1134940-power-supply-help/#findComment-13133976
I love to open the links you guys provide and see something like that ?
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1134940-power-supply-help/#findComment-13134045
