Usually quoted max length is about 10-15m - but for 4K HDR it might be less.
F@H
GPD Win 2
https://linustechtips.com/topic/1134387-hdmi-cable-length/#findComment-13128617
From personal experience, you should be able to go up to 7m as long as its a good cable.  Finding a good cable can be tricky though, the manufacturers lie.
https://linustechtips.com/topic/1134387-hdmi-cable-length/#findComment-13128620
I've read about fibre optic hdmi cables. Would they work? They're kinda expensive
https://linustechtips.com/topic/1134387-hdmi-cable-length/#findComment-13128805
You just need to look for a Premium High Speed certified HDMI cable. There is no specific maximum length defined by the specification. There are practical limits to what can be achieved but as a consumer all you need to look for is whether the cable has passed the certification or not.
https://linustechtips.com/topic/1134387-hdmi-cable-length/#findComment-13128904
