I have the catalyst 14.1 drivers and want to revert so I have uninstalled the drivers using the 13.12 express uninstall and the computer is not rebooting the monitor is off and so is the keyboard and mouse but the tower has the fans running and is on.
it has been 15 mins now and I am not sure if I should press the power to shut it down.
[CPU] i7 4790K OC [CPU Cooler] H100i [GPU] Evga GTX 980 SuperClocked [Ram] Corsair Vengeance 16 GB 1866 mhz [PSU] Cooler Master 1000w Silent Pro [storage] 256 GB Samsung 840 Pro, 1TB Seagate SSHD, 1 TB WD Blue 4 TB Seagate Nas. [Motherboard] Msi Z97 Gaming 5 [Case] Phantom 410 Red [sound] Onboard ALC 1150 [Headphones] Sennheiser HD 558 [Keyboard] Razer BlackWidow Chroma  [Mouse] Razer Deathadder Chroma [Mouse] Razer FireFly [Monitor] Asus MG278Q
https://linustechtips.com/topic/113434-uninstalling-graphics-software-help/
ok i shut it down but when i turn it back up the keyboard and mouse does not work.
anyone?
Dont double post use the old post
As for your problem, shut down then see what happens
I got no keyboard or mouse and usb is not working I cant log in
  • 4 weeks later...
Unplug your mouse and keyboard. Wait 1 minute, and plug them back, and wait a minute. See if they work. If not, try different USB ports.
No that did not work I have found out that if you have a AMD cpu and a AMD graphics card doing a express uninstall will delete your USB drivers also. So I had to repair my windows.
