Hi guy’s this is my first post and I could use a little help, so I just bought 16gb of trident z rgb 3200 to pair with a kit I already had installed, now I can’t get it to boot properly at 3200 with the xmp settings the kits are the exact same just bought couple months apart.
My parts
asus b450f mobo
ryzen 2600
32gb tridentz rgb memory 3200 all have the same timings
things I’ve already done
Pulled battery and cleared cmos
re installed ram
ran memtest86 and no problems
https://linustechtips.com/topic/1133976-need-help-with-ram/
My parts
asus b450f mobo
ryzen 2600
re installed ram
Try to manually set them to xmp, by using ryzen master. Set the same timings and mhz in ryzen master than in bios and leave everything in auto
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1133976-need-help-with-ram/#findComment-13125205
My parts
asus b450f mobo
ryzen 2600
re installed ram
Can you boot into windows with the new kit only?
If you can boot into windows with each kit one at a time and run this program and take a screenshot
http://www.softnology.biz/files/thphn160.zip
Hit the read button and select Read SPD doesn't matter which one you select. Wanting to check to see if the kit is using a different chip brand ect.
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
https://linustechtips.com/topic/1133976-need-help-with-ram/#findComment-13125211
2 minutes ago, boggy77 said:
ryzen 5 2600 doesn't play nice with ram speeds over 2933. you'll have to either manually increase dram voltage to 1.4V or something and see if it works or dial back the frequency to 2933
Not sure where you get your info but gen 2 chips and get up to 3400Mhz no issue on 4 dimm kits. 3600Mhz can be a be a pain at times but can be done.
3200Mhz is will work no issue, the problem here most likely is the the memory kits are using different die manufactures therefor causing a latency issue during training.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1133976-need-help-with-ram/#findComment-13125223
i get my info from my own experience and from countless people on this forum that had the same problem as me and solved it in the way i described.
xmp is an intel friendly profile. sure, you can activate it on ryzen, but might have to tweak a few things to make it stable. I suggested the 2 easiest options. either increase voltage or reduce frequency.
https://linustechtips.com/topic/1133976-need-help-with-ram/#findComment-13125227
Well memory is one of the hardest aspects to understand when OCing and dealing with bios settings. Yes XMP is a intel profile but is also baked into AMD motherboard because the motherboard manufactures make intel boards as well and have access to these profiles. I don't disagree that sometimes you may have to tweak some settings but without knowing root cause of the instability just pushing move voltage or decreasing frequency is not the right way to deal with the issue.
As i stated in my prior post most likely issue im just assuming while waiting on more information from the OP the kit has changed die manufactures which in my extensive experience and knowledge about ram  regardless of the same memory timings will result in a difference in memory latency that will cause the system instability. This can be corrected by changing RAS to CAS delay without tweaking the voltage or frequency and it will correct the inbalance in the system and allow both kits to operate at a fixed latency usually the kit with the highest latency.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1133976-need-help-with-ram/#findComment-13125246
is this what you're looking for or should i do each kit separately
https://linustechtips.com/topic/1133976-need-help-with-ram/#findComment-13125291
Do each kit separately.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1133976-need-help-with-ram/#findComment-13125779
4 hours ago, J3ff said:
each kit done separately at 3200
Thanks for that looks like the kits are the same no changes.
When you say you cannot get it to boot properly what does it do after you apply XMP profile with all 4 sticks installed?
Just to be sure you had the first kit in slot 2 and 4 and the new kit in slot 1 and 3 correct?
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1133976-need-help-with-ram/#findComment-13127620
Neat, please post more knowledge like this, there is serious lack of oldschool discussion about memory tweaking for both OC and compatibility these days, especially around places like this.
https://linustechtips.com/topic/1133976-need-help-with-ram/#findComment-13127640
I agree anymore people think just just up the volts until it works. Without knowing where the problem lies it like putting a bandaide on things, yes there is a place for more volts but if a kit is rated for said speed and a CPU IMC is rated for said speed at a certain voltage thats what you should be running for that speed if it doesn't work say due to poor motherboard trace shielding or even a weaker IMC this can be compensated by tweaking the Termination Block Resistance. This wouldn't affect your memory timings or require a increase in voltage. Once a kit is running stable or tweaked just past XMP then OC'ing becomes easier even on setups with 4 dimms you have headroom for voltage increase timing adjustments ect.
As I saw alot memory is one of the hardest components to understand true OC'ing if you don't know the "rules" for timings and what each timing parameter does and how it affect the memory.
My buddy has a 3600Mhz kit that is Samsung B die 16-16-16-20-36 @ 1.35v Gskill Kit 4x8GB kit I was able to get that memory up to 4400Mhz 18-20-20-22-42 @ 1.425v on a Ryzen 3600 Set SOC voltage to 1.2v I made timing changes to alot of the sub timings loosing them. But by the time we were done we saw almost a 20% increase in performance. We had to mess with the infinity fabric run it outside of the 1:1 his max FCLK was around 1850Mhz.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1133976-need-help-with-ram/#findComment-13127667
Well it try’s to boot but fails then shows me this screen i can boot with all four sticks running at 2666 with d.o.c.p and yes the original two sticks are in slot 2&4 the new ones are in 1&3 I’m also putting a pic of the settings
https://linustechtips.com/topic/1133976-need-help-with-ram/#findComment-13127761
Can you show me bios settings for timings and the rest of your voltage page please.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1133976-need-help-with-ram/#findComment-13127772
Also what bios version are you on?
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1133976-need-help-with-ram/#findComment-13127774
4 minutes ago, J3ff said:
I’m on version 2.17.1246 So you want a pic of the dram timing control page and I’m not quite sure where to find the voltage page
The Bios Version Number I want is at the top of the Main Page.
The voltages I want to see is in the AI Tweaker under Tweaker's Paradise.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1133976-need-help-with-ram/#findComment-13127801
May sound slightly OT and kind of too broad a question to easily answer, but where would one find better resources for understanding ram OC? Ryzen DRAM Calculator might be cool, but because of it there isn't anything that easily comes up if one searches for better understanding with how to OC Ram.  I find one or two old guides but nothing that comprehensive, or likewise find stuff that is way more technical then need be (starts going into deep computer-science, stuff you can't really play with in any bios, rather then just understanding basic of Ram OC)
 could ask more specific stuff but would rather make another topic or dm if you were interested, as i dont wanna drag this thread OT
https://linustechtips.com/topic/1133976-need-help-with-ram/#findComment-13127811
1 minute ago, J3ff said:
Ohhh my bad I should have known that it’s 1201
Okay so lets start with installing the latest chipset drives. Use the original kit to get into windows.
Then flash the BIOS to the latest version.
Under Tools in the BIOS use ASUS Ez Flash 3 utility
Link for chipset driver
https://dlcdnets.asus.com/pub/ASUS/mb/03CHIPSET/DRV_Chipset_AMD_AM4_VGA_19H1_TP_W10_64_VER191016_20190705R.zip
Link for Latest BIOS update 2901
https://dlcdnets.asus.com/pub/ASUS/mb/SocketAM4/ROG_STRIX_B450_F_GAMING/ROG-STRIX-B450-F-GAMING-ASUS-2901.zip
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1133976-need-help-with-ram/#findComment-13127820
Sent you a DM.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1133976-need-help-with-ram/#findComment-13127836
Ok I will do that tomorrow I have to be up at 5am and it’s almost 1am I’ll let you know when I’ve done it thanks for all your help
https://linustechtips.com/topic/1133976-need-help-with-ram/#findComment-13127839
Just now, J3ff said:
Ok I will do that tomorrow I have to be up at 5am and it’s almost 1am I’ll let you when I’ve done it thanks for all your help
No problem, just let me know, I will be on and off over the weekend, once you completed the steps I have you do a BIOS reset for good measure sometimes timings like to get stuck in limbo. After that is done reinstall all 4 stick and set XMP and see what you get and let me know.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1133976-need-help-with-ram/#findComment-13127843
ok so i updated the chipset driver and the did the bios, no luck i was able to hit 2933 last night now i can only hit 2800, so my situation has gotten worse.
and both kits still hit 3200 when i run them in duel channel
https://linustechtips.com/topic/1133976-need-help-with-ram/#findComment-13129670
