I was just wondering if anyone knew of or has bought from any laptop battery replacement website that actually carries decent/well made batteries. I've bought laptop batteries off of Ebay and Amazon before, but the quality of the batteries from 3rd party sellers were terrible (held half the charge at best). Could anyone point me to the direction of a respectable 3rd party battery website?
Thanks.
https://linustechtips.com/topic/1133586-laptop-battery-replacement/
Thanks.
LiIon wholesale
thebatteryguys
almost anything besides amazon and ebay really.  Those are the worst places for real batteries.  A lot of straight out counterfeits and people buying dead battery packs and “refurbishing” them with bad and/or used parts.
these are more pure battery sellers though.  Technically you need a battery pack. (A bunch of batteries in a box) The batteries inside the box are the bits that are important.  There are only a few “real” battery manufacturers but a lot of fake ones.  Samsung, LG, Panasonic, and Sony.  Everything else is generally garbage.  Computer manufacturers will buy from those.
