PC biuld:
every time i turn on the PC all the lights flash even the small 4 motherboard LED's on the top right corner, and all the the fan spin at max RPM but no signal on the screen
i have tried everything for about 6 hours now and it still not working, please dont tell me stuff like check if your PSU is switched on or check if you installed the RAM correctly because i already did them all, and i did everything on the the README thread , please tell me if you need any additional information. Thank you
https://linustechtips.com/topic/1133429-pc-works-but-its-not-booting/
27 minutes ago, Big-Boy said:
i just wanna know whats wrong with the pc so i can fix it
and we need to somehow determine that without trying any common fixes.... alright , maybe someone else would like to take on this challenge
@Big-Boy Easy.  Your running a 3rd gen Ryzen chip on a 2nd gen Ryzen motherboard. Update the bios on your motherboard to accept 3rd gen Ryzen CPUs.
Also you don't list a GPU. This CPU does not have integrated graphics. It needs a dedicated GPU.
And next time don't be snide in your posting. We understand that your frustrated but we ask the simple questions so we can assist you.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
Thank you for your help, it says on the motherboard box that its 3rd gen ryzen compatible, and how can i update the bios if its not posing? and the GPU is a GTX 1080 founders edition, i really appreciate your help.
Unfortunately this motherboard doesn't support bios flashing without a CPU. Your best bet is to take it to a computer shop and see if they can update the bios. Or the other option is to get a 2 generation CPU to update it yourself. A shop might do it for free or for about 30 bucks. It all depends on the shop.
Current Build
AMD Ryzen 2600
Stock cooler
1tb SKHynix m.2
WD 1TB HDD
Phantek fans
Phanteks P400TG
Laptop
Ryzen 7 5800h
1tb Samsung m.2
1tb WD black m.2
