Does audio on mini-itx boards crackle?
Go to solution Solved by BrinkGG,
4 minutes ago, AshesAndWool said:
Hi guys, I am building an audio production workstation and I am going to be connecting a high end external dac to a thunderbolt 3 port on the motherboard. I was thinking of buying the Asrock mini itx tb3 phantom gaming motherboard, but it struck me today that there might be electrical interference with the audio signal on such a compact motherboard. So my question is: is it possible to have audio interference (Either when listening or recording to a drive) through an external dac connected with thunderbolt 3, and if that case should I go with the bigger atx motherboard instead? Thanks.
My two motherboard options:
https://www.amazon.com/X570-Phantom-Gaming-ITX-TB3-Thunderbolt/dp/B07VXYYG7F/ref=sr_1_21?keywords=Phantom+gaming&qid=1575908653&sr=8-21
https://www.amazon.com/Z390-DESIGNARE-Gigabyte-Thunderbolt-Motherboard/dp/B07K8RJZRG/ref=sr_1_1?keywords=Designare&qid=1575908638&sr=8-1
Nope. Thunderbolt is a digital signal to your A/i. As long as you have your DAC configured properly, you shouldn't have crackle. If you do and you know everything is configured correctly, then you have dead or dying hardware somewhere in your signal chain.
EDIT: ^This is all true of any DAC, Audio interface, or any USB audio device. Not just for these motherboards on TB3.
https://linustechtips.com/topic/1132720-does-audio-on-mini-itx-boards-crackle/
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
If you're using an external DAC then nothing on the mobo design would affect anything, you're not using anything audio from it.
I have the Intel version of that ASRock board (Asrock Z390 Phantom Gaming-ITX/AC) and the onboard analog audio is clean too.
F@H
GPD Win 2
