I bought an after market cooler and will need to reapply thermal paste. Never having done this before i wanted to know what the best way was and how to do it properly (link a video?) iv'e seen spreading the thermal paste over the cpu with a note card and putting a pea sized drop of thermal paste in the middle of the cpu and in lines on the bottom of the cooler and then letting the coolers weight spread the paste.
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/11327-best-thermal-paste-applying-method/
Different people have different methods. For me, the "pea on the CPU heat spreader and let the cooler spread it for you" method has worked pretty well. Don't put thermal paste on both the chip and the cooler!
Better to watch what is wrong as well ;)
Desktop: Intel Core i7-5820K, Corsair H115i, Asus X99-Deluxe/USB 3.1, G.Skill Ripjaws4 32GB 2800MHz CL16, Zotac RTX 3070, Samsung 950 Pro 512GB in Angelbird Wings PX1, Samsung 850 EVO 1TB, 5*Seagate 12TB, Cooler Master V1200, Phanteks Enthoo Luxe, Windows 10 Pro. Phillips 328P6VUBREB, Corsair Vengeance K95 RGB Cherry MX Brown, Logitech G502 X Plus, Sennheiser HD700.
AYANEO 2S: AMD 7800U, 32GB 7500MHz, 2TB WD SN850X. Windows 11.
Like this!
hehehe just kidding don't do that.
Do this:
Workstation: 3930k @ 4.3GHz under an H100 - 4x8GB ram - infiniband HCA  - xonar essence stx - gtx 680 - sabretooth x79 - corsair C70 Server: i7 3770k (don't ask) - lsi-9260-4i used as an HBA - 6x3TB WD red (raidz2) - crucia m4's (60gb (ZIL, L2ARC), 120gb (OS)) - 4X8GB ram - infiniband HCA - define mini  Goodies: Røde podcaster w/ boom & shock mount - 3x1080p ips panels (NEC monitors for life) - k90 - g9x - sp2500's - HD598's - kvm switch
ZFS tutorial
Different people have different methods. For me, the "grain of rice on the CPU heat spreader and let the cooler spread it for you" method has worked pretty well. Don't put thermal paste on both the chip and the cooler!
Oh hey we linked the same video ;P
ZFS tutorial
Haha, it is Logan after all :D I was going to link the Kentucky way too! :D
wow, great video! Thanks and i think i'll go with the pea method :)
Like this!
Do this:
I live in indiana right above kentucky so should i use elmers glue instead of toothpaste?
Linus liked using the line method because it has the best consistency in his opinion. Here is a TechQuickie on applying thermal paste:
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
Depends on your thermal paste! For normal(?) thermal paste i use the pea method, for 'harder' thermal paste like arctic silver i would use the line method
i'm using what comes with the cooler, iv'e read its pretty good, only 1-2 degree difference than using arctic silver
I'm using stock compound too :)
Pea method should work fine
stock compound buddies for life! :D
It depends on the viscosity of the TIM. AS5 has uber high viscosity so it's a bit hard to spread, same with other metal TIMs. Ceramic TIMs have low viscosity and therefore great consistency.
I would use the line method with thicker compounds. The dot method should be used with ceramics. PK-1 FTW!!
Also, if you're re-applying TIM on GPUs, use the dot method. The die is a square for both AMD and NVidia cards. NVidia uses an IHS on some cards but the die underneath is a small square. AMD doesn't use an IHS at all.
i know we're all dudes...but seriously: just read the instruction manual that came with the TIM or the cooler you're using.  it'll tell you either line or pea.
what are these... Instructions.. You speak of? X3
i'll be useing the paste that comes with the CM hyper 212 evo
Im a bit different i use a circle with an x in the middle as i get better temps with it and its not mainstream(his hipness is over 9000)
Listen if you care.
Am I doing it right?
Lian Li PC-V359WRX Micro-ATX Case | Intel 5960X Extreme 3.00GHz | ASRock Fatal1ty X99M KILLER | Crucial 32 GB 2666 DDR4 | Thermaltake NiC C5 | EVGA Supernova 1200W P2 | 2x 240GB OCZ Radeon R7 | 2x 256 GB Samsung 840 Series Pro | 2 X 120GB Samsung 840 EVO | 6x NF-F12’s | Place Holder GPU R9 290X |
Links Current 5960X Old FX9590
