Hi, I am currently trying to build a gaming pc,I have no idea about cpus and would like a little help. Im trying to play sims3/4 in medium to high setting. I dont want to spend more then 150 for mother board and cpu if possible. I know I will need advice on other parts but for now just cpu and motherboard is my main focus.
https://linustechtips.com/topic/113213-cpu-help/
150$ budget for both mobo and cpu combined or 150$ each?
https://linustechtips.com/topic/113213-cpu-help/#findComment-1513143
Plan your system as a whole instead of part by part.
Also, read before posting: http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/
https://linustechtips.com/topic/113213-cpu-help/#findComment-1513161
My apologies,150usd for both together. I have been looking into parts: for case, cooler master elite, ram: kingston 4gb 240 pin 8gigs,graphics card I chose the radeon hd 7750, or geforce gt 630. My budget is 500usd but flexible
Don't get a GT 630, get the 7750 for sure.
https://linustechtips.com/topic/113213-cpu-help/#findComment-1513211
Is a copy of Windows or any peripherals needed?
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/113213-cpu-help/#findComment-1515260
Windows is needed. Didnt factor that into budget. I have monitor, hdd, and dvd drive. Does it matter that it has an ide cord?
It matters that it's ide. You need an adapter or a new drive in that case. Considering the cost, you're better off with a new drive.
Will Windows be needed to be included in the budget?
https://linustechtips.com/topic/113213-cpu-help/#findComment-1515720
https://linustechtips.com/topic/113213-cpu-help/#findComment-1515745
no windows will not, and I can get a new drive, I was trying to salvage some of my old pc stuff but I can chuck it. Also someone said that an os is attached to your hdd, so its already on there? Although its probably vista. Sorry if im being annoying I just keep striking out when I get pre built pcs.
https://linustechtips.com/topic/113213-cpu-help/#findComment-1515765
The os is on the drive.
How's this look? http://pcpartpicker.com/p/2Qfmx
https://linustechtips.com/topic/113213-cpu-help/#findComment-1515802
