Nvidai & Amd in same system.
Go to solution Solved by miyabwah,
You could use it for F@H. There shouldn't be any performance difference. You wouldn't need a monitor to be plugged in.
My questions are :
Would it be worthwile to put my old gpu in the new setup?
Would i see any proformance increase or would it just hinder my new pc?
Would it need to have a monitor pluged into the old card or would it be better not to?
I am NOT looking to do sli/crossfire. I just want to know if putting the old card into the new system would be benificial.
New System:
i5-4430 CPU 3GHz
16GB RAM (2x8GB)
GTX 670
Very Basic Setup:
2HDD
Fan Cooled
Stock Clock on EVERYTHING
Dual monitor
Old GPU is a AMD "MSi-Ati HD 3400"
CPU: i5-4430 @ 3.0GHz RAM: 16GB GPU: GTX 670
ASRock Fatality H87 Performance Win 7 Pro
https://linustechtips.com/topic/113198-nvidai-amd-in-same-system/
F@H?
Foldering@Home
