Hey guys!
I have been having this issue for almost 4 days already every time I start up my computer every morning.
What happens is when I power up the PC, It beeps once then the splash screen of my motherboard appears then suddenly black screen then the PC powers off then turns on again. It repeats itself maybe 2 - 3 times before it finally boots up to Windows.
I'm worried that it could just suddenly go into a reboot loop forever.
I'm using Windows 8.1 btw. HELP!
CPU: Intel Core i5-4670k Mobo: MSI Z97 Gaming 3 RAM: Crucial Ballistix Tactical Tracer 8GB 1866 Video Card: MSI GTX 970 GAMING 4G SSDSamsung 840 Evo 250GB HDD: WD 1TB + 500GB Caviar Blue
PSU: EVGA SuperNOVA 750W G2 Case: Gigabyte GZ-G1 Mouse: Corsair M65 RGB Keyboard: Corsair K70 MX Brown MousePad: Corsair MM200
Steam/Origin/Uplay: renz62
https://linustechtips.com/topic/113159-reboot-loop-help/
Are you using a custom build or a pre-built branded computer?  if your using a custom build I would recommend clearing CMOS or reset your bios to default settings.   I would also advise checking your power supply and memory.  Even though it might not be its worth a shot.  Revert any overclocks and reinstall Windows 8.1 if needed.
Hope this helps, if you have any questions just ask :)
https://linustechtips.com/topic/113159-reboot-loop-help/#findComment-1512361
Normally these are power supply issues.
Check your motherboard for any blown caps.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/113159-reboot-loop-help/#findComment-1512379
Issues in CPU OC can cause this behaviour.
I haven't overclocked my CPU yet.
I checked my motherboard for any blown caps but all seems to be looking fine.
I'm using a custom built computer. I'll try that method if ever it goes into a reboot loop again. Thanks!
https://linustechtips.com/topic/113159-reboot-loop-help/#findComment-1517356
