Howdy.
1st time poster, long time lurker.  I haven't built a machine in at least 20+ years.  I decided to build one for the kids for the holidays.  I have watched and read a million videos and reviews, and have decided on the following main setup:
  • CPU: AMD Ryzen 5 3600
  • HDD: 250GB NVMe M.2 SSD
  • MEMORY: 16GB (8GBx2) DDR4/3000MHz
  • MOTHERBOARD: ASUS TUF X470-Plus Gaming
  • VIDEO: AMD Radeon RX 580 8GB
  95% of the time these games will be played: Fortnite, CS:Go, Tomb Raider, COD MW, Apex Legends, Red Dead 2.
  My question is what monitor to get?  120Mhz or 144Mhz?
  I am looking at a 24-27" monitor as that's all that will fit in the space.
  I was leaning towards a 120Mhz, as I figure most games will be played in Med to High at 1080p, unless you think the specs above can handle better.
  Help me get this last detail please so I can finish ordering stuff for Christmas.
  Thanks in Advance!
Craig
https://linustechtips.com/topic/1131097-20-years-since-last-build-help/
Removing the storage options, I have about $800 to build the system.
I have a 250GB NVMe M.2 which I want to put the OS and cycle between 1 or 2 games on there.  I also have a 1TB SSD and a 1TB Mechanical Drive for everything else.
Here's where I put my money allocations:
MB: $100
Processor: $175
Ram: $75
GPU: $200
Case: $75
PSU: $75
Storage: $100
Monitor: $150-200
Total: $1000-1100
Oh, and keyboard, mouse, display port cables, etc are covered.
This was my original build list I started with.  I updated today with things currently in stock at places, but with same specs:
Okey, so storage is not a problem. Your cpu is way too powerful for the gpu, it will be a bottleneck for the processor. Seems like a waste of resourses. Would you be interested in a cpu downgrade in exange for a better gpu? That way both will be in the same tier. I switched the psu also, I think you don't need more than 500~550w.
You can go with the 2600x if you want ($20 more) and about the RX 5700, you can buy that or the RTX 2060. Both are almost the same, get the cheaper one.
With that, your cpu and gpu will be more balanced. In a couple of years, just buy a Ryzen 4xxx and you have a future proof pc.
At least, that's what I think you should do if you are just gaming.
For more than 60 Hz, you'd want something better than RX 580.
Also, while Ryzen 5 3600 has very good value, the Ryzen 2600 has even better value at only $120 - those 70$ can go to a better video card.
If you'll find the performance insufficient, it's still a very good processor that will hold its value and you can sell it on eBay or somewhere with a small discount and go for a 8 core or 12 core later.
The motherboard below is good for up to 8 core and even 12 core processors, as long as you won't overclock such cpu.
I picked mATX format in case you'll want to use a smaller and potentially cheaper case.
If you have the budget, go up to a MSI B450-A Pro Max or MSI B450M Gaming Plus  or MSI Tomohawk MAX or stay with that Asrock x570 board  but in that case you'd have to change the case to ATX size, as the one below is mATX.
The GTX 1660 Super is around 10-25% more powerful as long as you play below 4K resolutions. Above let's say 3440x1440 the 6 GB frame buffer starts to show, and card slows down. Still, at 230$ it's a good performance for money.
It's about 5-10% faster than RX 590 which you can find for as low as 180-200$
At 2560x1440 high quality you'll get around 90 fps with this card, so if you tweak settings to medium-high you may get up to 120 fps. You could also play at 2560x1080 on a 2560x1440 monitor, and the image quality won't suffer, you'll just have black bars on top and bottom of the image.
Here's some options that look good to me:
PCPartPicker Part List
Type Item Price
Monitor Acer XG270HU 27.0" 2560x1440 144 Hz Monitor $269.99 @ Best Buy
Monitor LG 34UM59-B 34.0" 2560x1080 75 Hz Monitor $276.44 @ Amazon
Monitor AOC CQ27G1 27.0" 2560x1440 144 Hz Monitor $249.99 @ Amazon
  Prices include shipping, taxes, rebates, and discounts
  Total $796.42
  Generated by PCPartPicker 2019-12-04 16:04 EST-0500
