Hey guys, I'm planning on buying a budget gaming PC but I need help with a known good motherboard that suports 3rd gen Ryzens
Pc I'm planning to build:
RAM: Corsair CMK8GX4M1D3000C16 Vengeance LPX 8 GB (1 x 8 GB) DDR4 3000MHz
CPU: AMD Ryzen 5 3400G
PSU: Bequiet system power 9 (I have this PSU at the moment)
Storage: Kingston A400 128gb M.2 SSD
GPU: None at the moment (Vega 11 APU)
Case: Corsair SPEC-DELTA Carbide Series
Does the case have good airflow and some extra clearance foe hiding cables from a non modular PSU?
Please recommend me a good mobo that would support the 3400G and doesn't cost more than £70 on Amazon UK
https://linustechtips.com/topic/1131090-1st-build-advice/
what budget for whole pc?
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1131090-1st-build-advice/#findComment-13101814
Roughly £320, I just want something that would handle GTA V, Rust, The forest or rocket league at 1360x768 at medium/high settings and later down the road I will throw in an RX580 4GB which will then make it much more usable for somewhat decent gaming
https://linustechtips.com/topic/1131090-1st-build-advice/#findComment-13101891
