6 minutes ago, jake1010 said:
I want to hook 5 case fans and 1 cpu cooler up to a b450 steel legend motherboard. how would i do it? it only has one 4 pin connector.
Hello,
A fan hub will do the trick :)
https://pcpartpicker.com/product/fqRFf7/silverstone-pwm-fan-hub-system-cables-black-cpf04 for example
https://linustechtips.com/topic/1130999-fan-help/#findComment-13101217
