Lian Li PC-O11DW 011 Dynamic
Vertical mounting 360mm Radiator with 3 fan pulling into the CPU compartment. Would add 3 more 120mm pushing behind the back of the rad increase performance?
Thanks
AMD Ryzen™ 9 3900X
GIGABYTE X570 AORUS ULTRA Motherboard
Trident Z Neo DDR4-3600MHz CL16-16-16-36 1.35V 32GB (2x16GB)
MSI GeForce RTX 2080 TI GAMING X TRIO
Lian Li PC-O11DW 011 Dynamic Tempered Glass on The Front Chassis Body SECC ATX Mid Tower Gaming Computer Case White
SAMSUNG 970 Pro M.2 NVMe PCI-E 1TB Solid State Drive
XPG S40G 512GB RGB 3D NAND PCIe Gen3x4 NVMe 1.3 M.2 2280 Internal SSD
WD WDS500G2X0C 500GB High-Performance NVMe PCIe Gen3 8 GB/s M.2 2280 Solid State Drive
Corsair Vengeance 750M 750 W (750W) 80 Plus Silver Semi-Modular Power Supply
Acer Predator XB273K UHD IPS NVIDIA G-SYNC Monitor, VESA Certified DisplayHDR 400, Quantum Dot, 144hz
BenQ 27 inch 4K PhotoVue Photographer Monitor (SW271)  - Secondary for Photo/Video Edition
EKWB EK-KIT S360 Compact Triple 120mm Water / Liquid Cooling Kit 360mm
Corsair STRAFE Mechanical Gaming Keyboard, Red LED, Cherry MX Blue
Corsair Nightsword RGB, Performance Tunable FPS/MOBA Gaming Mouse, Black, Backlit RGB LED, 18000 DPI, Optical
Sony HT-MT300/B Powerful Mini Sound bar with Wireless Subwoofer
https://linustechtips.com/topic/1130434-lian-li-pc-o11dw-011-dynamic-rad-fan/
You'd be better off mounting 3 along the bottom pulling fresh air right into the GPU
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
