Well only one of them would be compatible with a Ryzen cpu, so I guess the second one
If you're worried about compatibility, go use pcpartpicker.com. It will guide you through everything, no hassle
https://linustechtips.com/topic/1130392-help/#findComment-13096466
5 minutes ago, lee32uk said:
Only the middle board is for AMD. The other two are Intel boards.
If you want a cheapish ATX board for Ryzen then look at the MSI B450-A Pro MAX.
https://www.amazon.co.uk/dp/B07W837QSF?tag=pcp0f-21&linkCode=ogi&th=1&psc=1
Thankyou for your help
https://linustechtips.com/topic/1130392-help/#findComment-13096483
