Microphone problem
Go to solution Solved by Bomb7,
31 minutes ago, Enderman said:
Post some pictures of the windows sound control panel.
Try the headphones with the splitter on another PC or laptop to see what happens.
i'm the dumbest person on earth, turns out my heasdset has a mute button on it
My headset microphone makes a static sound and i do not hear myself through it. I have checked everywhere and cannot find a fix. I was also told to check my uncheck all enhancements under the enhancements tab for my microphone, but there is no enhancement tab for me.
link to my headphone (they just arrived today): https://www.amazon.co.uk/Audio-Technica-ATH-AG1X-High-Fidelity-Closed-Back-Headset/dp/B01AYZZUDC?th=1
https://linustechtips.com/topic/1129520-microphone-problem/
Ah yes, the _____ headphones, which everyone knows about.
The solution is to _______ the _______ while changing _______.
https://linustechtips.com/topic/1129520-microphone-problem/#findComment-13090299
my headset: https://www.amazon.co.uk/Audio-Technica-ATH-AG1X-High-Fidelity-Closed-Back-Headset/dp/B01AYZZUDC?th=1
sorry for forgetting
https://linustechtips.com/topic/1129520-microphone-problem/#findComment-13090312
Are you using a 4 pole to dual 3 pole splitter?
https://linustechtips.com/topic/1129520-microphone-problem/#findComment-13090324
i don't know what that is but this is what my splittler looks like: https://www.ebay.co.uk/p/3-5mm-Y-Splitter-2-Jack-Male-to-1-Female-Headphone-Mic-Audio-Adapter-Cable-UK/4026152605
https://linustechtips.com/topic/1129520-microphone-problem/#findComment-13090330
https://linustechtips.com/topic/1129520-microphone-problem/#findComment-13090403
https://linustechtips.com/topic/1129520-microphone-problem/#findComment-13090466
