Hi everyone, I am new to this forum but not to the LTT channel.  I am not sure if this is in the right section.  I hope there is a solution to the advice I require.  My sons has asked me if I can help to get apex legends running smoothly on our pc.  ( i am having a really hard time financially and I cannot afford  new pc)  Is ther anyway to get this pc improved performance.
the pc build is:
amd fx-8320 - i did not overclock it
Asus R9 270x - i did not overclock it
cpu cooler -  stock amd
16gb (2x8gb) corsair vengeance
Motherboard Asus M5a99fx pro r2.0
thank you very much everyone
https://linustechtips.com/topic/1129209-requesting-advice-on-pc/
Without getting new hardware your best bet is going to be overclocking. Otherwise you could try and get a used gpu, you can get gtx 970 or 980 for decent prices used, that would be your best bet without breaking the bank
Optical Drive Poll: https://linustechtips.com/main/topic/1006309-optical-drive-survey/
Main Rig (Pulsar)
CPU: Ryzen 7 5800X MOBO: MSI MEG X570 Unify RAM: Corsair Dominator Platinum RG(4x8gb) 3200Mhz 16-16-16-32 GPU: EVGA GTX 1080 FTW ACX 3.0 Cooler: Noctua NH-U12S Chromax (LTT Edition) Storage: Intel 6000p 128gb boot drive, Intel 665p 1tb (x2), Samsung 850 EVO 1tb, Case: Phanteks Enthoo Pro M Tempered Glass PSU: EVGA SupeNOVA G1+ 750W OS: Windows 10 Pro 64 bit
FreeNAS Server (The Vault)
CPU: Xeon E5-2603 v3 MOBO: MSI X99 Tomahawk RAM: G.Skill Aegis (4x8gb) 3000Mhz 16-18-18-38 GPU: EVGA GT 710 Cooler: Cooler Master Hyper 212 LED Storage: Intel S3520 x2 for boot, x16 in RAIDZ for storage, Seagate Ironwolf 2tb (Striped will be a steam cache) Case: Phanteks Enthoo Pro Tempered Glass PSU: Corsair CX750 750W
Your best option will probably be to upgrade the video card.
Look into a RX 590 or something faster, depending on your budget.
If you want cheap, probably a used RX 570 would still be a noticeable improvement and would cost less than 100$
Next would be cpu, but you'd have to replace motherboard and ram as well in that case.
It would be about 250$ ... ~ 120$ for a Ryzen 2600 , 70$+ for a motherboard, ~ 60-80$ for 16 GB of memory
I forgot to mention the ps:  XFX - 750W, 80 Plus Bronze Single +12V Rail
As i have built this pc myself, i fel confident that i can overclock it, but have never attempted this, I guess I will need to do some reading.   What about adding a 2nd graphics card?  the mb can handle it and the ps should be able also.
thanks again
thanks again
You'd be better off getting a newer card rather than running two older ones. Newer titles don't really support dual cards anymore, at least not naively. If you don't have a budget to work with at the moment be sure to do the following:
  • Update your motherboards BIOS
  • Update your drivers (refer to the link above)
  • Uninstall your display drivers using DDU and install the newest revision
  • Update Windows and avoid running anything in the background while in game
  • Overclock your CPU and GPU (it will take some time and research on your end but it will help, you will need a better CPU cooler)
  • Keep the game on low detail, better to keep the frame rate up and the game playable
  • Hope this helps, GL ?
Or you could turn down settings...
