So I have an old alienware x51 R2 I believe with an i7-3770, 16gb of DDR3 Ram 2x8, a GTX 1060 3GB, a Samsung 860 Evo SSD 512GB, and whatever motherboard or power supply or anything else that is in the PC. I was planning on upgrading my motherboard to allow for upgradability in the future but the problem I ran into was that I would need a new case, new ram, a new motherboard(obviously), and a new CPU at the least. I'm still not sure if I would need to get a new power supply or not or anything else. What I found was that at micro center I could get a Ryzen 7 2600X with a Wraith Prism Cooler for $129.99, Corsair Vengeance LPX 16GB 2 x 8GB DDR4-3200 for $59.99, an ASRock B450 PRO4 AM4 ATX AMD Motherboard for $52.96 after rebate, and a $34.99 Thermaltake ATX case with a tempered window after $30.00 rebate. I added these up and I got $277.93 without tax but I'm on a budget so I was wondering if anyone has any ideas or input that would help me decide how to upgrade to allow for future modifications.
https://www.microcenter.com/product/501730/corsair-vengeance-lpx-16gb-2-x-8gb-ddr4-3200-pc4-25600-cl16-dual-channel-desktop-memory-kit-cmk16gx4m2d3200---black
https://www.microcenter.com/product/505632/amd-ryzen-7-2700x-37ghz-8-core-am4-boxed-processor-with-wraith-prism-cooler
https://www.microcenter.com/product/509729/B450_PRO4_AM4_ATX_AMD_Motherboard
https://www.newegg.com/black-thermaltake-core-g21-tempered-glass-edition-atx-mid-tower/p/N82E16811133353?Item=N82E16811133353&nm_mc=AFC-RAN-COM&cm_mmc=AFC-RAN-COM&utm_medium=affiliates&utm_source=afc-PCPartPicker&AFFID=2558510&AFFNAME=PCPartPicker&ACRID=1&ASID=https%3a%2f%2fpcpartpicker.com%2fproduct%2fQ6YWGX%2fthermaltake-core-g21-tempered-glass-edition-atx-mid-tower-case-ca-1i4-00m1wn-00&ranMID=44583&ranEAID=2558510&ranSiteID=8BacdVP0GFs-164qDiZZZz7dYGQ7IKD0aQ
https://linustechtips.com/topic/1129113-cpu-upgrade/
rebates don’t always happen. Iirc at one point someone noticed that only 20% of rebates are actually successfully collected.  Most people forget or don’t fill them out right.  If they do they can often take a year.  If you don’t fill them out perfectly they throw them away.
https://linustechtips.com/topic/1129113-cpu-upgrade/#findComment-13087786
