Just now, Nick N. said:
Thank you sir.
If I remember right 2x GPU blocks, a big 240mm-ish tall res, and a 45mm thick 280mm rad + 560 mm rad took about 1.3L of fluid so you'll probably use a bit less but better to have extra just in case :)
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
my loop is a 280 30mm Raid and a 360 25mm rad with CPU/GPU and a 140ML res and it takes up exactly 1L of fluid, so 2 for sure as @Lurick suggested.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Mine (All EKWB) is 2 x 1080TI full blocks, CPU block, 140mm reservoir, Phanteks distribution block, 240mm SE rad, 240mm PE rad and 420mm SE rad. All up about 1.25 litres.
