Hello. I'm trying to essentially upgrade from years of playing on a mediocre laptop (Which would run Overwatch only on the lowest settings/render @ 35-60~ at best, and TF2/CSGO around 60+ depending on situations) to something that can actually run something like R6 without needing to be at a horribly small resolution and low settings.
I'm trying to keep everything below $850 USD, and so far I have, however I am mainly looking advice on the parts I currently have selected in mind, to see if there's anything I could swap for better value/price, or that may cause an issue by itself.
I only plan on a single monitor for the time being.
My main concerns would be the MB as it has some noted cons with spacing issues, the GPU being the most expensive part right now, and I'm unsure if there will be enough cooling for everything.
Also, if there's any extra parts/wires/etc. I might need, or just general advice/feedback, it would be greatly appreciated.
Thanks.
Update: Tweaked some stuff based on recommendations. If there isn't anything else to say about this, then I'll probably be going with it after a bit more searching. Thanks to those who tossed some suggestions my way.
Update 2: More changes. If anyone comes across this with any more feed back, I'm open to it.
(New)
(Old)
https://linustechtips.com/topic/1127662-first-build-looking-to-keep-below-850/
Here's something you might want to consider:
The Meshify is a very good case, you might want to add a few fans for good airflow.
The deep blue sky is infinitely high and crystal clear.
私はオタクではありません。
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  ($114.99 @ Amazon)
Motherboard: ASRock B450 Pro4 ATX AM4 Motherboard  ($79.99 @ Newegg)
Memory: *Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3000 Memory  ($49.99 @ Newegg)
Storage: *Team MS30 512 GB M.2-2280 Solid State Drive  ($41.99 @ Newegg)
Storage: *Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Amazon)
Video Card: MSI Radeon RX 5700 XT 8 GB MECH OC Video Card  ($389.99 @ B&H)
Case: NZXT H510 ATX Mid Tower Case  ($69.98 @ Amazon)
Power Supply: *Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  ($59.99 @ Newegg)
Total: $856.91
Generated by PCPartPicker 2019-11-25 21:18 EST-0500
check this one out. though you might want to change things around a bit.
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
Noted.
Might I ask why the 1660S would be better than the 1660 TI? Aside from being about 10$ cheaper, since the TI has slightly better performance. Unless you only swapped it due to price.
Otherwise thanks.
Total: $856.91
Not sure if I'd prefer going that high on the GPU in regards to price, but I'll probably swap back to the MS30, and check out the MB and RAM.
Thanks.
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($194.00 @ Amazon)
Motherboard: ASRock B450M Pro4-F Micro ATX AM4 Motherboard  ($71.00 @ Amazon)
Storage: Team MP34 512 GB M.2-2280 NVME Solid State Drive  ($58.99 @ Amazon)
Video Card: ASRock Radeon RX 5700 XT 8 GB CHALLENGER D OC Video Card  ($349.99 @ Newegg)
Case: Deepcool MATREXX 50 ATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($34.99 @ Newegg)
Total: $848.94
Generated by PCPartPicker 2019-11-25 22:30 EST-0500
1 hour ago, SubZeroDestruction said:
Noted.
Otherwise thanks.
The 1660S and 1660ti are very similar in specs and performance. There's not much difference really, other than the prices you mentioned. I just put it there because it was newer than the TI and the EVGA was a better brand in my opinion.
私はオタクではありません。
1 minute ago, Xiee said:
The 1660S and 1660ti are very similar in specs and performance. There's not much difference really, other than the prices you mentioned. I just put it there because it was newer than the TI.
Gotcha.
