I have Xperia C5 Ultra Dual, it started getting a little hot after I open chrome and after a few seconds, I get the "Unfortunately UI has stopped working" label popping up. In other phones I press ok and it does a refresh and becomes normal. But this doesn't work here, I repeatedly get that error and I have to reboot, then the same happens. I uninstalled chrome updates, it was running fine, updated it, became unstable again. Any fixes?
It's Marshmellow, as far as I can remember, will check. All every system update done.
https://linustechtips.com/topic/1126975-system-ui-has-stopped-chrome-heating/
