7 minutes ago, limun32 said:
CPU
AMD AM4 Ryzen 7 2700X
GPU
AMD Radeon RX 590 ASRock PHANTOM GAMING X OC 8GB
RAM
DIMM DDR4 2X8GB 2400MHz
MB
Gigabyte AM4 B450M S2H DDR4
PWS
800W Raidmax Cobra RX-800AE-M
your gpu weaker than your cpu, but still great system, you should get atleast radeon 5700 or 1660 super
And dear god get better ram than 2400mhz get 16gb 3200mhz cl 16 ram.https://www.amazon.de/gp/slredirect/picassoRedirect.html/ref=pa_sp_atf_computers_sr_pg1_2?ie=UTF8&adId=A044796324HP7YG2VVBGY&url=%2FCorsair-Vengeance-3000MHz-Performance-Arbeitsspeicher%2Fdp%2FB0134EW7G8%2Fref%3Dsr_1_2_sspa%3F__mk_de_DE%3D%C3%85M%C3%85%C5%BD%C3%95%C3%91%26keywords%3D3200mhz%2Bcl16%26qid%3D1574519393%26s%3Dcomputers%26sr%3D1-2-spons%26psc%3D1&qualifier=1574519393&id=6774326394437992&widgetName=sp_atf
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
7 minutes ago, SavageNeo said:
if i buy 2x8gb ram clock at 3200 mhz but on mb site says Support for DDR4 3600(O.C.)/3466(O.C.)/2933/2667/2400/2133
9 minutes ago, limun32 said:
hmmm what about ryzen 5 2600x or 2600
nah your fine. bottlenecking is not that big issue, it will not break anything, you do not have to upgrade your cpu in years, but you should upgrade your gpu in year or so
yea thanks its kinda high end pc where i live maybe i will go with ryzen 5 2600 or 2600x or maybe better gpu but frist i gotta earn money to buy :) anyway thanks for your help kind sir
NP.
Yeah buy that rx590 and r7 2700x. Then in two years upgrade your gpu, since your cpu is so powerfull that it will last atleast 5 years
33 minutes ago, limun32 said:
PWS
You ought to not get a raidmax PSU.
Since 800 watts is a ton, why not get a more reasonable 450 or 550 watts and shoot for something along the lines of a Corsair CX or be quiet pure power?
Primary PC:
PSU tier list
How many watts do I need?
I think it actually makes more sense to get a stronger cpu than gpu. Realistically you are more likely to upgrade your gpu before your cpu and it will be much easier to upgrade that than your cpu which could potentially need a new motherboard or ram. You can't really bottleneck a cpu with a less powerful cpu, you just won't use its full potential
Optical Drive Poll: https://linustechtips.com/main/topic/1006309-optical-drive-survey/
Main Rig (Pulsar)
CPU: Ryzen 7 5800X MOBO: MSI MEG X570 Unify RAM: Corsair Dominator Platinum RG(4x8gb) 3200Mhz 16-16-16-32 GPU: EVGA GTX 1080 FTW ACX 3.0 Cooler: Noctua NH-U12S Chromax (LTT Edition) Storage: Intel 6000p 128gb boot drive, Intel 665p 1tb (x2), Samsung 850 EVO 1tb, Case: Phanteks Enthoo Pro M Tempered Glass PSU: EVGA SupeNOVA G1+ 750W OS: Windows 10 Pro 64 bit
FreeNAS Server (The Vault)
CPU: Xeon E5-2603 v3 MOBO: MSI X99 Tomahawk RAM: G.Skill Aegis (4x8gb) 3000Mhz 16-18-18-38 GPU: EVGA GT 710 Cooler: Cooler Master Hyper 212 LED Storage: Intel S3520 x2 for boot, x16 in RAIDZ for storage, Seagate Ironwolf 2tb (Striped will be a steam cache) Case: Phanteks Enthoo Pro Tempered Glass PSU: Corsair CX750 750W
