Hello!
FINALLY, next month I'll have everything ready to start my cable sleeving, it's going to be black and yellow themed, since I love these colors, and simply because a lot of parts in my PC have this color scheme.
But as of now, I have a question for you guys to answer for me: I have this cable (look below)
post-9910-0-42127600-1391819805_thumb.jp
... and my question is, what kind of connector is it on the end of this sata power cable ? PCI-E or AUX ?
Which one should I buy out of these two ?
AUX: http://lutro0-customs.com/products/10-pin-female-connector
PCI-E: http://lutro0-customs.com/products/6-pin-female-pci-e-connector
Thanks in advance, and sorry if you're facepalming while reading this and saying "what a noob", I know, but I always prefer being 100% sure of what I'm buying and thanks to you guys, I'll be set.
VIDEO GAMES                                  Max Power Build Log
https://linustechtips.com/topic/112608-cable-connectors-question/
Hello!
What power supply is this from?
It could possibly be a propitiatory connector which cannot be purchased.
I know my AX1200i has proprietary connectors.
From the picture you posted and comparing the two connectors from Lutro Customs. It isn't the PCI connector though it could be a AUX.
As the second pin in the top row is similar just looking at it.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
@AndyCapets Looks like PCI-E power like for a graphics card, but I believe it's the modular connector for the PSU.
Air 540, MSI Z97 Gaming 7, 4770K, SLI EVGA 980Ti, 16GB Vengeance Pro 2133, HX1050, H105840 EVO 500, 850 Pro 512, WD Black 1TB, HyperX 3K 120, SMSNG u28e590d, K70 Blues, M65 RGB.          Son's PC: A10 7850k, MSI A88X gaming, MSI gaming R9 270X, Air 240, H55, 8GB Vengeance pro 2400, CX430, Asus VG278HE, K60 Reds, M65 RGB        Daughter's PC: i5-4430, MSI z87 gaming AC, GTX970 gaming 4G, pink air 240, fury 1866 8gb, CX600, SMSNG un55HU8550, CMstorm greens, Deathadder 2013
De-pin it and use it.
No it's a Lepa, so every connector fit's on it. I'll probably get the AUX one.
 Thing is, that it's made out of poor quality plastic and I already broke one of these connectors on the second sata cable and had to send it for it to be replaced and also, I bought a set of wires and pins to make custom cables myself to not ruin the original cables and so I need one of these connectors.
And yes, it looks exactly like a PCI-E one, but I don't think that the connector is the same on these.
Ok guys I answered my question myself quite easily actually, just by looking at the connector, the sata power cable that I have needs an AUX connector to work because when you look at it...
... an AUX connector goes like this: rounded, squared, squared
                                                        squared, rounded, rounded
And a PCI-E goes like this: rounded, rounded, squared
So yeah, I need to buy an AUX connextor, thanks anyways guys!
