So,  I bought Artic 1.5mm Thermal Pads and I'd like to know if they're gonna get the job done... Can you help me?
CPU: AMD Ryzen 7 7700X @ 5.6GHz (single core boost) | 5.4GHz (all cores); Mobo: Asus ROG Crosshair Hero X670E; RAM: Team Group T-Force 2x16GB (32GB) DDR5 @ 6000MHz CL38; GPU: RTX 4080 - ZOTAC GAMING AMP Extreme AIRO; Case: NZXT H7 Flow; Storage: Kingston KC3000 1TB + Adata Legend 900 2TB; Cooling: Cooler Master PL360; PSU: Corsair HX 1200
https://linustechtips.com/topic/1125786-thermal-pads-gtx-1080-turbo-oc/
but why?
Desktop benching:
10 minutes ago, Jurrunio said:
but why?
'cause they were dry, "brittle" and kinda old.
i'm on thermal paste rn.
You cant replace paste with pads, they conduct heat so much worse. Paste is paste, putty is putty, pad is pad.
Desktop benching:
I know, that's why I got new ones, And I'd like to know if they will get the job done on being "satisfying" pads in my case...
if you are padding the VRM or the Vram, then good, if the GPU die then no.
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
Yeah, just the vrms and Vram. The GPU itself I got Kryonaut for it.
Oh and btw
Yeah thank you Gigabyte. My one year warranty way over dead already.
Anyhow, thank you both @Martin2132 and @Jurrunio
Any pad will work. Cheap stuff or expensive stuff. Won’t matter as you nor the card will notice the difference.
Should be more concerned about having the correct sizes to replace it all.
