So currently I'm rocking the Stock Cooler from AMD's 2400g APU and it's honestly good for my current needs, but my goal is to upgrade every stock part to something slightly better...
So my question is which Cooler is best?
This one : https://www.amazon.com/NOCTUA-NH-L9i-chromax-Black-Low-Profile-Cooler/dp/B07Y3M88QF/
or
This one : https://www.amazon.com/Cooler-Master-RR-212S-20PK-R1-Contact-Silencio/dp/B07H25DYM3/
Edited by LogicalDrm
Shortened links not allowed
https://linustechtips.com/topic/1125749-cpu-cooler-upgrade/
The NH-L9i is tiny, it's only "better" if you need to move your PC to a space that's too small to fit the stock cooler. The 212 black is better, along the same lines as the Wraith prism, but the prism is way more attractive honestly and you can get em off eBay for good prices.
AMD also sells the wraith max, which is basically the same thing with less RGB, by itself for around the same price.
https://pcpartpicker.com/product/8XX2FT/amd-wraith-max-558-cfm-cpu-cooler-199-999575
Edited by Fasauceome
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1125749-cpu-cooler-upgrade/#findComment-13062646
I actually just got the Noctua NH-L9i Chromax and with an amd socket I would strongly not recommend. It requires a sold separately mounting kit which is about $8, no big deal, but swapping the mounting is ridiculous. The screws you need to remove are philips and are far to weak, they almost immediately get ruined. I got three out very carefully but the first was ruined and I had to take a dremel to it to remove it. Upon further reading amazon reviews I found that others had this issue with AM4. They make one specifically for AM4 but not in black, that should be fine. I will say it does not have a ton of cooling capacity its really meant for small form factor builds. I use it on a 1700X and it will hit around 80ish degrees while stress testing which is perfectly fine, but if you are not limited by space I would get something with more cooling capacity and better AM4 support
Optical Drive Poll: https://linustechtips.com/main/topic/1006309-optical-drive-survey/
Main Rig (Pulsar)
CPU: Ryzen 7 5800X MOBO: MSI MEG X570 Unify RAM: Corsair Dominator Platinum RG(4x8gb) 3200Mhz 16-16-16-32 GPU: EVGA GTX 1080 FTW ACX 3.0 Cooler: Noctua NH-U12S Chromax (LTT Edition) Storage: Intel 6000p 128gb boot drive, Intel 665p 1tb (x2), Samsung 850 EVO 1tb, Case: Phanteks Enthoo Pro M Tempered Glass PSU: EVGA SupeNOVA G1+ 750W OS: Windows 10 Pro 64 bit
FreeNAS Server (The Vault)
CPU: Xeon E5-2603 v3 MOBO: MSI X99 Tomahawk RAM: G.Skill Aegis (4x8gb) 3000Mhz 16-18-18-38 GPU: EVGA GT 710 Cooler: Cooler Master Hyper 212 LED Storage: Intel S3520 x2 for boot, x16 in RAIDZ for storage, Seagate Ironwolf 2tb (Striped will be a steam cache) Case: Phanteks Enthoo Pro Tempered Glass PSU: Corsair CX750 750W
https://linustechtips.com/topic/1125749-cpu-cooler-upgrade/#findComment-13062763
Slightly better in what way and for what purpose?
https://linustechtips.com/topic/1125749-cpu-cooler-upgrade/#findComment-13063706
4 minutes ago, TheWahmenRespektor said:
Overall... Sound and performance... I can't overclock for some reason, my MOBO doesn't support it so i'll just be on stock speeds.
What motherboard are you using and how are you trying to oc?
What are your temps and how much quieter of a cooler do you need?
https://linustechtips.com/topic/1125749-cpu-cooler-upgrade/#findComment-13063713
b450m ds3h , running a Ryzen 2400g... Tried overclocking through the bios itself and i cannot even try because it's grayed out
I don't really need SUPER quiet, I just don't want the current ones I have. They make a weird sound that I cannot describe, it's not typical fan noise but something else...
https://linustechtips.com/topic/1125749-cpu-cooler-upgrade/#findComment-13063719
Please be specific. What's grayed out?
Are you sure the noise is from the cpu cooler? Does lowering the fan speed or stopping the fan stop the noise?
Make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them.
https://linustechtips.com/topic/1125749-cpu-cooler-upgrade/#findComment-13063729
Take a look @ the picture I posted, It's not my motherboard I just googled it... Those boxes that drop down are what I'm talking about, I went to the portion where it's CPU overclock and Ram overclock, those are grayed out... Even the manual overclocks where you have to type in manually are not usable... I tried lowering the speed of my fan but the weird noise I'm talking about just gets quieter.
https://linustechtips.com/topic/1125749-cpu-cooler-upgrade/#findComment-13063739
What options are available under Ai Overclock Tuner?
If lowering the fan speed lowers the noise, the issue is probably the fan.
https://linustechtips.com/topic/1125749-cpu-cooler-upgrade/#findComment-13063744
