I will be soon building this pc https://pcpartpicker.com/list/XV8CZN or sth similar. I have however my mind split about what case to buy. I love the white 011 dynamic but it comes with no fans and doesn't fit most cpu air coolers. Also I like the coolernaster mb530p. I would love it if you could suggest me some cases and give me your opinion. Also aesthetics do matter to me. Thnx
https://linustechtips.com/topic/1125732-which-case-for-build/
I have always been a fan of the nzxt cases, they come with case fans and if you get the models with a "i" in the name, you get a smart fan controller that you can use nzxt cam to control along with the rgb it comes with. The cases are great values, I would check out the h510i case.
Pc Specs:
Ryzen 7 5800x- ROG STRIX X470-F  - G.Skill Trident Z RGB 16gb 3200mhz - Kraken X63 AIO - MSI VENTUS 3x OC RTX 3070 - EVGA 1000W GW - NZXT H500i
https://linustechtips.com/topic/1125732-which-case-for-build/#findComment-13062548
Not sure what you're looking to spend on the case but Corsair has always had excellent budget options with their SPEC-0X lineup of mid towers. I recently got a phanteks full tower and my friend got a mid tower from them and it was really easy to build in with great quality. Both will usually give you at least 2 or more fans
Optical Drive Poll: https://linustechtips.com/main/topic/1006309-optical-drive-survey/
Main Rig (Pulsar)
CPU: Ryzen 7 5800X MOBO: MSI MEG X570 Unify RAM: Corsair Dominator Platinum RG(4x8gb) 3200Mhz 16-16-16-32 GPU: EVGA GTX 1080 FTW ACX 3.0 Cooler: Noctua NH-U12S Chromax (LTT Edition) Storage: Intel 6000p 128gb boot drive, Intel 665p 1tb (x2), Samsung 850 EVO 1tb, Case: Phanteks Enthoo Pro M Tempered Glass PSU: EVGA SupeNOVA G1+ 750W OS: Windows 10 Pro 64 bit
FreeNAS Server (The Vault)
CPU: Xeon E5-2603 v3 MOBO: MSI X99 Tomahawk RAM: G.Skill Aegis (4x8gb) 3000Mhz 16-18-18-38 GPU: EVGA GT 710 Cooler: Cooler Master Hyper 212 LED Storage: Intel S3520 x2 for boot, x16 in RAIDZ for storage, Seagate Ironwolf 2tb (Striped will be a steam cache) Case: Phanteks Enthoo Pro Tempered Glass PSU: Corsair CX750 750W
https://linustechtips.com/topic/1125732-which-case-for-build/#findComment-13062668
I personally prefer the Phanteks P400A. Has great airflow, can fit most air-coolers with no issues and is a great value. Easy to build in and is bigger than it looks. Plus you can get it with or without rgb.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/1125732-which-case-for-build/#findComment-13062751
P400A is an awesome case, its like a better big brother version of the P300 with a lot better airflow
Main Rig (Pulsar)
https://linustechtips.com/topic/1125732-which-case-for-build/#findComment-13064701
