780ti and a AMD gpu in the same machine?
Okay, so i built a system with the intent of having one SSD as a boot drive for windows, and the other for a mystery operating system that i was going to research, and i came across OSX mavericks, which won my decision as a no BS OS, i had debian wheezy on the other SSD for a while and after trying to fix many things such as the resolution as well as other things. So i already have a 780ti in my machine playing nicely with windows 8.1, however I have read posts around the interwebs that the 780ti doesn't exactly work with opencl, which is clearly a big issue when it comes to OSX. I saw a linus video the other day where the PC had 2 780ti in SLI and 2 290X in crossfire.
Would it be worth getting an AMD card?
Would i be able to set it to turn on when OSX is booted, but not when windows 8 is booted and vice versa with the 780ti?
If so, i was thinking a 270X, is that a good choice.
Please only reply if you know what you're talking about, i know im only a rookie in the forums but i have got so many answers on my threads that tell me what i already know, and then i just end up searching it anyway.
Much appreciated.
AMD cards don't really work that well in OSX, you're better off using an Nvidia card, but the 780, 780ti and Titan don't support it in 10.9 Mavericks. You could always play it safe an run 10.8 Mountain Lion, there isn't that much difference. The 780ti will support OpenCL only in 10.8 Mountain lion not 10.9 Mavericks.
Don't buy an AMD card for OSX as it will most likely not work if at all and use 10.8 for opencl.
