I'm looking to upgrade my current air cooler to an AIO and I'm just wondering what people think the best option would be. I don't really want to spend more than $130/140. I've been looking at the Cryorig A40, but I just saw that the Corsair H100i RGB Platinum is on sale for $129 instead of $159. Which one would be the best? Or are there other options I should look into? I can only fit a single or dual fan rad in my case btw.
CPU: R7 3700x
Mobo: Asrock x370 Taichi
Case: NZXT s340 Elite
https://linustechtips.com/topic/1125267-best-aio-cooler/
CPU: R7 3700x
The best AIO is an air cooler :D
Otherwise the H100i RGB Platinum is a good unit :)
https://linustechtips.com/topic/1125267-best-aio-cooler/#findComment-13058578
AIO coolers are all pretty much perform within margin of error with each other. Pick the one that fits the budget and if you can hold a 240mm rad in the PC case. After that pick one that you enjoy the styling of and if you want rgb or not. After that you cannot go wrong.
https://linustechtips.com/topic/1125267-best-aio-cooler/#findComment-13058598
CPU: R7 3700x
The best AIO cooler IMO would be the EVGA CLC 360, it's a good value, quiet when it needs to be, and has the highest RPM fans available on an AIO.
https://linustechtips.com/topic/1125267-best-aio-cooler/#findComment-13058877
