I'm trying to use SpeedFan to get some control over my radioator fans, as that was what Gigabyte recommended for my motherboard.
Anyways, I'm fiddling around, finding the correct fans and so on. Then I'm firing up Prime95 to test my fan curve. Once the test started, the fans went crazy, looking at HWiNFO, the CPU temps instantly goes up to 80 degrees. SpeedFan also reports these temps. It stays at around 80 and wont go down, until I stop the test and the temps instatntly plumits back down to 34.
Here is an image of the temps, when starting and stopping the stress test:
CPU: i7 4790k
MB: Gigabyte Z97X-Gaming 3
https://linustechtips.com/topic/1123943-cpu-reporting-wrong-temperatures/
...as if we'll know the problem without knowing what you actually have in there?
Desktop benching:
Just now, Celsiuss said:
LOL, sorry edited first post
not enough, we still need to know the cooler, preferably whether you replaced the thermal paste or not, the case, the case airflow, and the GPU.
Desktop benching:
Alright,
The CPU is cooled by an AIO CoolerMaster liquid cooler, double radioator 140mm fans mounted on the top of the case. The case has 3 intake fans and 3 exhaust fans with an open air style GTX 1080 Ti. Thermal paste has not been replaced since I built it 4 years ago.
Replace the thermal paste first then
better if you mention model, rad size is not the only factor of performance
Desktop benching:
If the thermal paste is dried up and not conducting heat then yes, the CPU can heat up that quickly.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
