Screen problem
Go to solution Solved by MCM04,
7 minutes ago, Oshino Shinobu said:
Hard (impossible) to say what exactly caused the damage. Something could have fallen on it, you closed it too hard, you sat on it, someone else sat on it, there was something on the keyboard when you closed it etc. etc.
Even if you say you didn't do anything, that definitely looks like physical damage to the screen. Unless you had a camera pointed at the laptop for the past week, you may never find out what caused it.
EDIT: Also, the damage doesn't have to be from the screen side, it could be from to back side. So something being placed on it too hard or with too much weight could have caused it. If it has been closed all week, then my guess is that either there was something between the screen and keyboard when you closed it last, or an impact of some sort occurred on the back side of the screen when it was close
Arrr , ok thx mate ?
if you squint you can just barely make out a huge crack in the center of the whole dang screen
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1123937-screen-problem/#findComment-13048813
16 minutes ago, Oshino Shinobu said:
I don't really see a question to answer...
If you want to know the cause, definitely physical damage, you can clearly see the origin point of the damage.
But it's impossible I didn't do anything to the PC and it didn't move from it's place
https://linustechtips.com/topic/1123937-screen-problem/#findComment-13048830
EDIT: Also, the damage doesn't have to be from the screen side, it could be from to back side. So something being placed on it too hard or with too much weight could have caused it. If it has been closed all week, then my guess is that either there was something between the screen and keyboard when you closed it last, or an impact of some sort occurred on the back side of the screen when it was closed.
https://linustechtips.com/topic/1123937-screen-problem/#findComment-13048834
https://linustechtips.com/topic/1123937-screen-problem/#findComment-13048851
