How do I control fan speeds?
Stark_Source
High everyone,
So I've just put my rig together, and I'm noticing the fan speeds are just constant, no matter what my rig is doing. I plugged each fan into the relevant fan slots on the board (CPU, SYS1, and SYS2). Is there not a way for the mobo to regulate fan speed on the basis on temp? Current temps are 6, 20, and 20 degrees.
Any help appreciated...
CPU: AMD FX-8350 █ MOBO: Gigabyte GA-990FXA-UD5 ATX AM3+ █ FAN: Noctua NH-D14 65.0 CFM █ RAM: Ballitix Sport 16GB (2 x 8GB) DDR3-1600 █ GPU: MSI GeForce GTX 780 3GB █ SSD: Kingston SSDNow V300 Series 120GB  HDD: Seagate Barracuda 2TB 3.5" 7200RPM █ PSU: EVGA 750W ATX12V / EPS12V █ Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tow Monitor: Dell P2414H 23.8"
Check your bios
Most motherboards can change speed based on settings in the BIOS.
Most motherboards come with software that can control the fan headers on the Motherboard.
Speedfan (http://www.almico.com/speedfan.php) works in the majority of cases.
Or you can get an external fan controller which lets you do it manually with buttons/switches on the case.
Also, I need to say this....
It's "Hi Everyone"....
"High Everyone" isn't English, requires more letters, makes no sense, and annoys Grammar Nazi's like me...
Check your bios
Had a look, but it only had an option for one sys fan and it was 'normal' 'silent' or 'manual'.... I expected 'normal/auto' to be variable, but its constant.
I shall leave it in then. I don't mind annoying people ;-)
I downloaded speedfan, but wasn't sure how to use it...
At those temps, you don't need your fans to be faster... I think there's some programs like SpeedFan for that.
Yeah, I'm looking to reduce fan speed here, and I don't think they need to be always on, which they currently are.
Uhm.... 6 degrees would be WAY under the ambient temperature.... so whatever you used to measure temperatures, it is wrong.
"I see now that the circumstances of one's birth are irrelevant. It is what you do with the gift of life that determines who you are."
-Mewtwo
That's 6C.  it's 39F, 77F, and 89F
Neither EasyTune nor Speedfan seem to be able to adjust RPM. These fans are 3-pin, but surely there's an app to get variable voltages depending on temp?
Or maybe I just need to get new fans. They were stock fans with the Fractal Case.
I might also try to hook the fans up to the case fan controller and just keep an eye on temps.
Yea, 6 degrees Celsius cannot possibly be a component on your computer unless you're using liquid nitrogen to cool it. Ambient temperature is ~20 degrees Celsius.
-Mewtwo
So, even with a
So, even with a noctua fan going it couldn't be 6C? What's gone wrong do you think?
