Hey, so ive completed my loop but my 9900k is still running really hot (at least to me, im aware its a hot chip)
So on idle im getting 45 degrees C and say running games itll hit up to 70-75C (there have been cases where ive seen it hit 80C)
9900k and 2080ti is being cooled in the loop with 2x 360mm rads (top exhaust and front intake)
Cpu temps are aitting around 45-55c idle and say topping at about 75c under gaming loads) using hwinfo for core temps. It summer in australia right now but my room isnt incredibly hot id say its about 25c in my room so id expect my cpu to be about 30c not 45-55.
Is there something im missing? Ive reseated and repplied paste, cleaned my cpu block, still getting same temps
https://linustechtips.com/topic/1122467-temps-are-pretty-high/
Is the CPU overclocked?
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
https://linustechtips.com/topic/1122467-temps-are-pretty-high/#findComment-13036630
Thats a whole bunch of hot components. That actually doesnt surprise me too much. Buuut, we are missing a whole bunch of info
Copper or aluminum loop?
Case?
Rad placement?
Pump/Pump Speed?
Overclocked?
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
https://linustechtips.com/topic/1122467-temps-are-pretty-high/#findComment-13036685
Case?
Rad placement?
Pump/Pump Speed?
Overclocked?
Copper or aluminum loop - copper (Ni plated) loop
Case - Lian Li o11 Dynamic
Rad placement - havent replaced it, but running 2x 360mm slims
Pump/Pump Speed - pump would be a distro block from bitspower, front panel sedna for o11 dynamic
Overclocked - yes, 5ghz all cores 1.245v
https://linustechtips.com/topic/1122467-temps-are-pretty-high/#findComment-13036879
I see nothing out of the ordinary then. Those are 2 VERY hot parts.
Useful threads:
Total: $1891.98
https://linustechtips.com/topic/1122467-temps-are-pretty-high/#findComment-13036942
What’s the layout given that case? I’d assume a lack of air at some point. Which rads are they? You’ve ran ran the pump and fans at max already? Decent fans for a slim rad with high fpi?
https://linustechtips.com/topic/1122467-temps-are-pretty-high/#findComment-13036949
layout goes, cpu > top ek 360mm SE rad (exhaust) >  side rad (same as top rad, intaking air) > front distro block which then goes to cpu and gpu.
fans are ek vardar 120mm.
not at max spd, if its idle itll be like 25% pump spd and fans are 50%, there are times i just leave pump at 50% and fans 50%
if im gaming then pump will be 50-70% and fans 70%
https://linustechtips.com/topic/1122467-temps-are-pretty-high/#findComment-13036956
So no fans at the bottom for fresh air?
Guess you could try with the side panel off and see how that goes.
Think air flow is poor. Given the case layout and the rads used.
I even did push/pull with it and it was quite limiting on flow.
https://linustechtips.com/topic/1122467-temps-are-pretty-high/#findComment-13036964
its possible but if i ramp the fans up to 70% i can feel the air blasting out at the top and the side is pretty good as well.
https://linustechtips.com/topic/1122467-temps-are-pretty-high/#findComment-13036968
Then there isn’t an issue.
https://linustechtips.com/topic/1122467-temps-are-pretty-high/#findComment-13037521
4 hours ago, Chaoz-Theory said:
so its normal to be idling around 50c?
You said the airflow is fine. I assume tim contact was already checked. So not much else to is.
https://linustechtips.com/topic/1122467-temps-are-pretty-high/#findComment-13039394
