So this isn't really a computer thing... but i hope someone out there can help me. My science fair project is using body temp/heat to charge a phone. I bought peltier tiles and a powerbank circuit (based on what i watched on yt) and soldered the red cable to b+ (from tile to circuit) and the black tile to b-, again following the video. But it doesn't work, im not sure if its because the temperature differences aren't extreme enough but im not sure how to keep one side hot while the other cold. if anyone could help me that would be deeply appreciated
thanks
Main Rig
CPU i5-8500 @3.8 GHz Motherboard Gigabyte H370 HD3 RAM 16 GB (8x2) Kingston HyperX Fury DDR4/2666 GPU MSI RX 580 8G Armor OC Case Corsair SPEC-05 Carbide Storage WD Blue 2TB 5400 RPM / Corsair MP510 2TB PSU Aerocool P7 650W 80+ Platinum Display Samsung S22D300 Cooling Deepcool GAMMAX 300
Keyboard Logitech G512 Carbon Mouse Logitech G502 Sound Logitech G431
Old Rig
CPU FX-6300 @3.5 GHz Motherboard Unknown RAM 8 GB (4x2) DDR3/1866 GPU ASUS GT 730 2GB GDRR3 Case Unknown
Storage WD Blue 500GB 7200 RPM PSU Cougar - Unknown Display N/A Cooling Stock Cooler
Portables
Macbook Pro 13" (early 2015, A1502)
i5 - 5257U / 8GB DDR3-1866 / 256GB SM0256G SSD / Intel Iris 6100
iPhone 8 / 64 GB with Sony WF-SP700N
https://linustechtips.com/topic/1121952-science-fair-project-help-plox/
