3 minutes ago, Smackaroy said:
Using kraken x62 with noctua fans 8700k stock temps just after stress test in real bench look at the middle column those are the max temp
They're fine, I had 75 degrees ish using realbench with a "stock" (+ MCE and XMP) on my non-delidded 8700k using a H100i v2 (Also Asetek 240 mm AIO).
https://linustechtips.com/topic/1121491-how-are-these-temps/#findComment-13029347
2 minutes ago, Smackaroy said:
Took the top panel and front panel off got a max of 66
Then even better, for reference mine was a closed Ncase M1 using stock fans
https://linustechtips.com/topic/1121491-how-are-these-temps/#findComment-13029356
4 minutes ago, Smackaroy said:
@For Science! question if I delid how much whould my temps go down approx and how much does it cost to do
Hard to say as the improvement differs a lot between people (say 5-20 degrees) but on average I think its fair to say that people improve 10-15 degrees with liquid metal. The cost also varies between how much tools you want to get (I would recommend getting it) so you need:
A tube of thermal grizzly conductonaut
Derbauer delid die mate 2
UHU silicon
So however much you can get it for in your country, for me I think its something like 30-40 euros.
https://linustechtips.com/topic/1121491-how-are-these-temps/#findComment-13029383
UHU silicon
That's not to bad thought it whould be 100-150 money's
https://linustechtips.com/topic/1121491-how-are-these-temps/#findComment-13029402
43 minutes ago, Smackaroy said:
I'm also using MCE
As a side note, unless if something has changed with MCE, it should be doing the single core turbo on all cores so it should send your CPU to 4.7 GHz all cores, but yours is 4.4 and so perhaps is more gentle than my boards MCE.
https://linustechtips.com/topic/1121491-how-are-these-temps/#findComment-13029478
I have a cheap eBay tool and bought the lm. Prolly didn’t really keep track of my temps for it but wanted to try it anyway.
From what I can remember it dropped 10c overall.
Gaming, running it at 4.5 @1.28 would sit at 60c or so. Pegged around 95% usage.
https://linustechtips.com/topic/1121491-how-are-these-temps/#findComment-13029690
Nice temps, but consider using the new snipping tool in windows windows button + shift + s ?
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1121491-how-are-these-temps/#findComment-13030397
Then I’d actually have to save them on the pc. And start up the pc come to this site, find the post again and comment. Way too much work for me.
https://linustechtips.com/topic/1121491-how-are-these-temps/#findComment-13030686
How did you get such good temps before you delided I've changed cooler fans and changing that stuff improved it but only by a bit starting to think I have a bad chip. Or is it that is have MCE on?
https://linustechtips.com/topic/1121491-how-are-these-temps/#findComment-13030847
My voltage goes up to 1.22 and get 70c and you had 1.28 and got 60c I don't get it
https://linustechtips.com/topic/1121491-how-are-these-temps/#findComment-13030878
I assume the somewhat low voltage, compared to my auto profile. The amount of cooling I run now and the ambient temps. Only having a 18-20c ambient. An aio isn’t gonna complete. That’s also with liquid metal.
https://linustechtips.com/topic/1121491-how-are-these-temps/#findComment-13030898
So is the 60c at 1.28v you had with liquid metal? And do you run a custom loop and what is normal temp for a 8700k with a 280mm aio?
https://linustechtips.com/topic/1121491-how-are-these-temps/#findComment-13030930
Yes 60c was before lm. I’m on a custom loop.
No no idea what the normal temp is supposed to be. You can prolly YouTube the cpu and fine some benchmarks.
https://linustechtips.com/topic/1121491-how-are-these-temps/#findComment-13030947
Do you recommend turning off MCE
No. It’s always on. Never a reason to turn it off.
https://linustechtips.com/topic/1121491-how-are-these-temps/#findComment-13030980
I'm a little confused a find people with great temps like jayztwocents like 60c stock then I find people with similar temps to me like Tom's hardware then I find people how get temps in the mid 80s my theory is that maby some chips have a better thermal paste application under the IHS than others.
https://linustechtips.com/topic/1121491-how-are-these-temps/#findComment-13031000
Well there are a million variables. Don’t see why it’s even a thought. It’s working and not throttling, shouldn’t really ask for much more.
https://linustechtips.com/topic/1121491-how-are-these-temps/#findComment-13031006
True just wanted to overclock a bit if I set the voltage 1.35 temps shoot up to 88c
https://linustechtips.com/topic/1121491-how-are-these-temps/#findComment-13031023
I’d just make sure you’re giving the aio the best chance it has. Being used as an intake and fans and pump at max. Then go from there. Maybe even do push pull and see where it gets you. I would delid right away but I’m not one for precaution.
https://linustechtips.com/topic/1121491-how-are-these-temps/#findComment-13031039
I'm using it as an outtake does making it an intake really make a difference,
https://linustechtips.com/topic/1121491-how-are-these-temps/#findComment-13031046
